Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 1000 posts to different brand TVs now. Pull up older posts there
That means the connectors to the actual LCD element are damaged.
It's unlikely anything can be done.
If it is still under warranty you may be able to get it repaired.
HI.usually when problems occurs without picture, either slanted picture has vertical or horizontal light on it.The one responsible for this is what we called ..PICTURE-TUBE.It is a cathode -ray tube in the television receiver that translates the received signal into a picture on a luminescent screen.It is the picture tube who creates an image that is composed of identical horizontal lines.So any problems in regards to picture whether it only shows vertical or horizontal.its the PICTURE TUBE that was damaged.Hope this idea helps..Thank you for choosing fixya.
If you have the same problem on any sources (dvd, tv...) then see with your retailer or directly with Sony customer services. There's a problem either with the display card or the panel.
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
i have the same problem, apparently the LCD panel needs to be replaced and this will cost more than the tv is worth... Advice is to not buy a sony again, because this is a common problem and they wont extend the warranty, even if its 2 weeks after it runs out...
Unfortunately he has damaged the screen, the only way to fix this is to have the screen replaced, this can cost almost the price of a new TV. If you have home contents insurance you could possible put in a claim for accidental damage.
sony bravia lcd troubleshooting https://www.google.com/search?client=ms-android-att-us&ei=O8blWLC3CIvKjwTi54DIDg&q=sony+bravia+lcd+troubleshooting&oq=somy+bravia+lcd+troubl&gs_l=mobile-gws-serp.1.0.0i22i30k1l5.154.16000.0.16940.47.34.1.3.3.0.1404.11353.0j9j4j5j2j2j3j2.27.0....0...1c.1j4.64.mobile-gws-serp..26.21.7197.3..0j0i7i30k1j35i39k1j0i131k1j0i67k1j0i10k1j0i13k1.Ar_4YkwTSbY
