I purchase the lg lht854 system at a pawn shop & it didn't come with the wires for the speaker what kind should i get & where can i purchase them at. Thank-you
You probably need to be a bit clearer as to what you want. But the f (function) key on the unit allows you to change the input To ARC if you have it set up. If you switch off your TV /stereo using the TV remote only this should shut down both. When you turn it on again both should turn on with the sound routed through your stereo ( when you turn on you need to wait a short while while the stereo starts up)
if you turned it on without speakers hooked to it you may have blown the speaker output amps or if the end of the amp remote wire touched a ground you may have burned a trace on the board did you here it play at the pawn shop? or did it just light up? sometimes the people at the pawn shop think if the unit lights up it is working and sometimes they check them is just hook power to them without speakers if so this can blow the speaker output I would take it back to the pawn shop
hello have you got an s video port on your tv if so i'd connect the theater system to this and use the md fuction on the stereo so you can listen to normal tv through the speakers good luck
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
Have you tried the VSM (Virtual Sound Matrix) button on the remote? I think you will have to scroll through the various sound processors ie..stage...virtual matrix..etc...to find the one that will have all surround speakers working. Hope this helps
I have an almost exact set-up and you will only get sound out of your rear speakers when the TV channel is broadcasting in 5.1 Ch Stereo. Otherwise the sound is limited to your front, center, and woofer speakers.
I had the same issue, but apparently...it's not an issue. What I discovered is that the system was fine, but the station I was watching didn't broadcast in 5.1 surround sound. Therefore, only the front speakers will have sound. Try putting a dvd in, or listening to a gameing system through it. If you don't have sound after listening to something that puts out full surround sound, then you know you have an issue.
All four of the small speakers are identical, the original speaker wires are color coded. the very ends are all black and red, corresponding to the black and red connections on the back of the receiver and on the speaker, and there is another color band lower on the wire, which corresponds to the color on the receiver speaker connectors that details front right, front left, rear right, rear left, center, subwoofer.
If you are using standard speaker wire, it has two colors. Pick one for the red, and one for the black.
Just be consistent and connect all speakers the same at both ends (Copper color to plus-red / silver color to minus-black)
