Use your remote. Press menu and look up initial set up or reset to factory settings.
* Note that as of Jan 2018 most cable companies do not provide analog outputs to TV sets. If your still using Channel 3 for an input to your TV then it won't work or will stop working some time this year.
* Hook up your TV using the old RCA video/audio jacks; Yellow plug is video, Red is audio right, White is audio left.
* You can also use an HDMI cable (best) for High Def picture which is all the rage for HD TV.
* You may also connect using the DVD style cable hook up which uses 4-5 separate cables (3 for colors and 2 for audio)
* Once you have some sort of video or message on the TV screen then you can proceed to setting up the cable box. Have the cable box hooked up and on for at least 15 mins. Look at the cable box display till the correct time is displayed. Power up the cable box till you see the power on indicator. Now use your TV remote to select the correct input you hooked your cables t. (probably HDMI) The display should show you your cable service. Now use the cable remote to select your channel.
* If you don't have a cable box but still have digital service (usually called basic cable - no premium) then use the analog/digital input on the TV remote and select initial set up. There should be an automatic channel search and set up to scan all the channels available on the line your connected to. This will take up to 15mins. If you know the specific channel you can cancel the scan and pick each channel for you own list. Letting the scan run may help you find other channels you are unaware of.
* Final; if your still having problems then call you TV MFR support line and they will talk you through to check your set.
* You can also check the cable company support line if the TV check out okay. The cable company may or may not be able to supply you service for really old Tube style TV sets as most if not all TV's are digital now.
Aloha, ukeboy57
None of the newer style TV's need a converter box because all the tv channel tuners use a digital signal. The tv signal in the air is now digital when using a tv antenna.
There are a couple possibilities here. Is the antenna a digital HDTV antenna, or is it a standard analog? The TV tuner must match the antenna type. Also, if you are using an analog antenna (old style), there may not be any analog broadcast stations in your area anymore as most have gone digital.
Check the settings to see if it is locked on channel 3 for external tuner source to have an input from a cable box ant in that needs 3 to function or from some other externally decoded signal like a vcr. Does the TV have a Digital tuner or the old analog tuner? If it's digital you can hook up a rabbit ear antenna with the UHF output on it & should be able to tune in some stations. If it's the old style then you will need a converter box to get it to receive any stations. Fist check the settings to see if it has it set to lock on channel 3 for external tuner source.
If your trying to receive over the air make sure the TV is not set to a Cable mode, if your on Cable your new TV is most likely a ATSC tuner (digital) and the cable company can map channels any way they want. If your old TV had the older style cable tuner, the lineup will be different.
HDTV has level thresholds, if the signal is weak you wont see anything, but the old TV would.
Without knowing much about where or what sort of TV your using, these are my best ideas.
I would assume that your using digital converter boxes for the sets that are not hooked up to cable? Do you have digital antennas? The old analog style will work but reception will not be so good. You can find digital antennas almost any major department stores. The boxes are still available at some locations. Since the broadcasting has gone digital for regular channels,analog tvs will no longer recieve stations with out a digital converter box. I hope this helps.
Using this button will set the Closed Caption mode when viewing a DTV or TV channel.
Enable Caption Using the TV Menu
Open the Menu screen, select the third icon, in the middle, this is the Setup Menu.
In the Setup Menu, choose the Caption option.
Caption: There are three items in it - Analog Closed Caption, Digital Closed Caption and Digital Caption Style
Analog Closed Caption: CC1, CC2, CC3, CC4, TEXT1,TEXT2, TEXT3, TEXT4.
Digital Closed Caption: Service1, Service2, Service3, Service4, Service5, Service6.
Digital Caption Style: There are two Caption Styles. One is the
automatic function set as the broadcaster, while the other is the custom
style where you can adjust the font size, color, opacity, background
color etc., accordingly.
The big TV change over should only worry people that use that old style antenna on their roofs. That is the analog system. Cable and satellite are digital systems. It is hard to find an analog TV set these days. If you have to twist a big knob on your TV to change the channels, then I would worry about 2009. You have a digital TV if you have a yellow video jack somewhere on the back.
