Question about Maytag Washing Machines
Maytag Bravos XL washing machine "normal" wash light is blinking and it won't start.
6ya staff
SOURCE:
Anonymous
SOURCE: maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
Posted on Jul 03, 2009
Anonymous
SOURCE: NORMAL Wash light is blinking and I can't CANCEL
We had the same issue with ours...tried turning off at the breaker, still didn't reset. Contacted appliance repair who came in and unplugged it from underneath the sink, waited a few seconds and plugged it back...dishwasher reset and repairman charged trip charge and labor $65 BUT problem is resolved and we now know what to do in the future.
Posted on Oct 18, 2009
Anonymous
  • 50 Answers
SOURCE: Our Maytag Bravos washing machine
du is the code for cannot unlock,,,,is there excessive weight on the lid, such as a basket of laundry? Excessive weight will keep the lid from unlocking. Press POWER/CANCEL once to clear the code.....
Posted on Jan 08, 2010
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: My Maytag Bravos quiet series
Hi and welcome to FixYa, I am Kelly.
My response is very long and will be in 2 parts this is PART 1
Here is what the service manual says about Ld:
"Ld" (Washer is taking too long to drain
water from the wash tub)
Check the following:
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See
"Connect the Drain Hose," page 2-5. Press
PAUSE/CANCEL to clear display
Also:
Is the drain hose clogged, or the end of
the drain hose more than 96? (244 cm)
above the floor?
See "Drain System," page 2-3.
6. To remove the drain pump: (there are 2 pumps... the drain pump is on the left)
a) Loosen the clamps and pull the inlet
and outlet drain hoses off the pump.
Note that there is a tab on the outlet
connector that fits into a slot in the
hose.
b) Remove the three 5/16? hex-head
screws from the drain pump and remove
the pump from the tub.
Check the pump inlet and the tub outlet for obstructions.
Pump electrical winding resistance test:
-Disconnect the wire connector from the
drain pump terminals.
- Set the ohmmeter to the R x 1 scale.
- Touch the ohmmeter test leads to each
of the drain pump terminals. The meter
should indicate between 10.5 and 14 ?.
----Due to the design of the machine the 2 wires going to the drain pump have be notorous for backing out of the plastic connector. Check the connector of the pump for loose terminal connections. --
From the Ld troubleshooting steps / procedure:
Long Drain
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96? ?
• Is the pressure hose connection from the tub to the machine/motor control pinched or plugged?
• Is the pump running? If not, see TEST #7.
TEST 7
TEST #7 Drain/Recirculation
Perform the following checks if washer fails to drain or recirculate.
1. See Activation of Manual Diagnostic Test
Mode, and perform the Manual: Pumps
test.
2. Remove the console to access the machine/
motor control assembly. See Accessing
& Removing the Electronic Assemblies.
3. Visually check that the P4 connector is
inserted all the way into the machine/motor
control.
If visual check passes, go to step 4.
If visual check fails, reconnect P4 and
repeat step 1.
4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1.
If resistance values are good, go to step 7.
If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem
exists in the motor winding or in the connection between the machine/motor
control and the motor. Go to step 5.
5. Tilt machine forward to access the bottom
of the machine and the pumps. See
Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and
take measurements across pump terminals. Measurements should be as shown in the wiring diagram.
If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the
pump motor.
If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/
motor control. Repair or replace the lower wiring harness.
If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check
the pump and tub sump for foreign objects before replacing pump.
7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
8. If the Manual: Pumps test failed, then the machine/motor control has failed:
Unplug the washer or disconnect power.Replace the machine/motor control assembly.
Perform the Manual: Pump test.
Posted on Nov 21, 2010
leoniv_arkus
SOURCE: my maytag bravos quiet series 300 washing machine
i lost the manual , what does "5d" mean when it is
Posted on Jul 04, 2011
My Maytag Bravos washing machine starts and spins very fast upon start button being pressed and very loud grinding noise
Hi Andrea,
not sure if this link will help you out but have a look.just scroll down the page and see if you can find what you need to help you out.
Maytag Bravos washing machine starts and spins very fast upon start button...
Nov 04, 2017 | Maytag Washing Machines
How to replace drum bearings on a maytag bravos xl washing machine?
Not just the bearing, you need the rear tub assembly and basket in case the shaft is damaged
Aug 19, 2014 | Maytag Washing Machines
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
How to replace bearing on maytag bravos washing machine
is it loud in spin if it is then change the bearings
Feb 02, 2014 | Whirlpool Washing Machines
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 30, 2012 | Maytag Washing Machines
I have loaded my Maytag Bravos and all the lights blink
Check door switch wiring or door switch or control board
Mar 09, 2010 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
