Question about Maytag Kitchen Ranges
Maytag Gemini appears to be in sabbath mode after power failure. Holding the clock button for 3 seconds as manual says does nothing, nor does holding it any longer than that. any suggestions
3 Suggested Answers
6ya staff
SOURCE:
EllaWatson25
Ella Watson
  • 725 Answers
SOURCE: Model/Serial#: MER5765RAW/15589899JR--exit sabbath mode
Try flipping off the breaker at the breaker box for about 10 minutes and see if it will reset itself. If you continue to have problems with it, just give us a call and we will troubleshoot this problem for you.
You can contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7AM until 7PM CST and we will be happy to get you cooking again.
We hope this helps and we look forward to working with you again.
Ella
Posted on Jan 07, 2010
oldTech2332
Gene Meier
  • 2341 Answers
SOURCE: my maytag gemini oven has been stuck in sabbath
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Posted on Oct 13, 2011
We had some sort of electric power failure last night lasting only a few seconds, but now none of the control buttons on the gas range function. In the time window 5a6 shows. No way to use the oven.
You are in Jewish Sabbath Mode, it is 'Sab'
Search Results Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab". To disable the Sabbath mode push and hold the Clock pad for 3 seconds.Nov 10, 2007
Maytag Oven WEIRD Error Code 5ab - Appliance Repair Forum
forum.appliancepartspros.com/oven.../2348-maytag-oven-weird-error-code-5ab.html Feedback
About this result
Will you tell me what error code 5A6 means on Maytag MGR6875ADQ ...
https://www.shopyourway.com/questions/1098960 Nov 24, 2010 - As indicated in the previous response, the 5A6 indicates that the range is in the Sabbath mode (SAb). The image below shows the information on this mode for your range. Press the CLOCK button and hold it for 3 deliberate seconds to cancel this Sabbath mode. The control should then work normally. what does the f-2 error code on my maytag oven mean?
26 Jun 2010
What does the SAB error code mean on my Maytag ...
1 answer
1 Jan 2010
How do I cancel the Sabbath mode on my Maytag range?
30 Dec 2008
What does an SA6 (or 5A6) error code mean on my ...
1 answer
13 Nov 2008
More results from www.shopyourway.com
Maytag Oven SAb error code - YouTube
? 0:54
https://www.youtube.com/watch?v=XUP1BOzqPUo Jan 1, 2014 - Uploaded by Life With Christ
The SAb error code will freeze your oven functionality and you will not be able to cook or program the oven ... Oven Repair including Ranges and Cooktops
Mar 12, 2018 | Kitchen Ranges
Maytag electric stove has an error code of 5A6. What does this mean?
It is not 5a6... it is Sab... (Sabbath mode)
Hello Susan Krim,
If you do not have your MODEL NUMBER
(nothing came through with your question)...
Find your original OWNERS MANUAL...
and look up how to DEACTIVATE the SABBATH feature...
ELSE...
Get the model number and go to my
favorite FREE manual site...
ManualsLib Makes it easy to find manuals online
Hope this helps... Next week too...
Carnac the Magnificent
Dec 18, 2017 | Maytag Kitchen Ranges
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
Or
NOTES:
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
The electronic panel related to oven and clock does not work. code 5ab appears on the display
Hello, welcome to FixYa.
Your range has somehow been set in "sabbath" mode ( for the Jewish calendar I think...not the metal band, lol ) If you have the owners manual turn to the section referring to this an it should instruct how to reverse the setting.
All ranges do it somewhat differently, so I can't say exactly how on yours. This example is generic, hopefully it works. If you are unsuccessful let me know the exact model number and I'll see if I can locate it.
Hold Clock pad for 5 seconds to activate Sabbath mode. Hold Clock pad for 5 seconds to disable Sabbath mode.
Oven must be in BAKE mode before enabling SABBATH. "SAb" displays and flashes for 5 seconds. All pad inputs are disabled except for CANCEL and CLOCK pads.
This mode disables the normal 12 hour shutoff to allow operation of the bake mode for a maximum of 72 hours.
Good luck. Thank you for choosing FixYa.
Regards,
Macmarkus :)
Jul 18, 2011 | Maytag Gemini 30" Self-Cleaning...
How to use sabbath mode on Maytag Gemini electric oven
Hello, Thank You for using FixYa. I will be helping you today.Holding the clock button puts it into sabbath mode.For all the info if you go to maytag website you can put in your model number and look at the owners manual.
Thank You and please rate my answer if it was helpful..
Jun 09, 2011 | Ovens
5A6 6ATH error message
Hi and Wlecome to FixYa, I am Kelly.
This is the Sabbath mode. Why it even exists is odd in itself.
Hold CLOCK for 3 seconds to disable the Sabbath mode.
This should get it back to normal operation.
Thanks for choosing FixYa,
Kelly
Dec 28, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
How do i get it off of sab bath
Sabbath Mode is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
The model number you listed this question under does not have the Sabbath Mode feature. I couldn't find it listed in the owner's manual. Do you have the correct model number? On most Maytag model ranges you press and hold the CLOCK button for either 3 or 5 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. If you have questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Apr 04, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Sabbath display makes oven inoperable
Hold the clock button "in" for 5 seconds to disable Sabbath mode.
Mar 14, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Oven and clock inop
You might have a problem with the circuit breaker - reset it by pressing the switch ocated on he lower edge of the backguard (in Canadian models). There are several things that could cause the oven not to operate, but generally you would get a message on the display - "Lock", "Sabbath" etc. Just in case your display is damaged and that's why you don't see any message, try to press and hold the "cancel" and "cook and hold" pads for three seconds (to unlock the oven in case it is locked), and then check to see if the oven works. if not, repeat this procedure (to make sure that you didn't lock it just now), and then press and hold the "clock" pad for three seconds (to unlock the oven in case it is in "sabbath mode"). If it still doesn't work, you might need to replace a fuse.
Apr 05, 2006 | Amana AER5515QA Electric Kitchen Range
Kitchen Ranges Logo
96 people viewed this question
Top Maytag Kitchen Ranges Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
