Computers & Internet Logo
r
rudy ruffo Posted on Jul 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Removing panels to access hard drive on gateway 835 gm
Larry Ng
Level 3:
Top Expert:
  • Gateway Master 14,591 Answers
  • Posted on Jul 20, 2019
Larry Ng
Gateway Master
Level 3:
Top Expert:
Answers
14591
Questions
0
Helped
3277837
Points
66570
Gateway omg old or is Acer made, now. made 2005, 14 years old.
omg2, relic Pentium D PC, wow. old.
there are 2 ways, mostly, (besides rear clam shells)
2 screws.
or the latch.
we are USA are you outside USA the USA GW lists no 835.
usa has 830. and 840. we pitch these the trash, no w10 support.
removing panels to access hard drive on gateway 83 - 835-zuzec33ptz3j1er1pnknd5pb-3-0.jpg
this looks like slider case to me. the rear side panels do not just pop off 1 by 1, no.
the clue If you look the top and sides are 1 part.
so that top rear screw release it, or the who front comes off pops off and screws seen there release the wrapper.
that is 1 odd duck case. it retire it in a heart beat.
some odd cases tilt the pc from top to rear look bottom front/s
see levers there in plastic and when tripped the whole front tilts off.
5 Related Answers
Anonymous
  • 188 Answers
  • Posted on Dec 24, 2007
SOURCE: Can't remove hard drive panel
Slide it one way or the other it hooks into the chassis.
Anonymous
  • 45 Answers
  • Posted on Jul 28, 2008
SOURCE: external hard drive
ya yiu can do it only you need is to download the drivers from the homesite of teh type of hard drive u r using
u hav not mentioned the name her so just simply try by searching google for the driver
dnewcombe1
Dana Newcombe
  • 1564 Answers
  • Posted on Aug 23, 2009
SOURCE: I am unable to remove the hard drive to install a
My Pavilion a1357c has only one screw on the open slider panel side, excuse me it only has screws on one side. Your only venue is to loosen that bracket until you can get access to that screw. Good luck my friend,Dana
Anonymous
  • 51 Answers
  • Posted on Feb 17, 2010
SOURCE: I just purchased a refurbished Gateway 835 Gm
Well youve paid for and got it know, so it shouldn't really matter. I think once you have something then you should not worry about the cost unless it starts giving hassle. I bought my PS3 and a few weeks later it dropped by 150€, but I have it and Im happy with it.
Anonymous
  • 2992 Answers
  • Posted on Feb 24, 2011
SOURCE: Gateway M305CRV is damaged. I
You need to connect the drive to another computer so the data can be read. The simplest way is with a USB adapter like this one. I got mine from thinkgeek.com, but it's available from other places too. This one's nice because it can connect to regular IDE, laptop IDE or SATA drives. Then you just plug the USB cable into any other computer, and you're set. I's like using any other external drive after that.
Where is the hard drive on a gateway all in one computer. i opened it up and dont recognize which part it is.
Hello.
Which model Gateway all in one do you have?
I have a Gateway ZX4800 and the hard drive is under the center rear cover. You have to remove the smaller panel that sticks out near the base of the PC (where the RAM is located) first then the center panel that is taller will pull out and reveals the hard drive cage. unbolt the hard drive cage, remove the SATA and power cables and you can then replace the hard drive.
On other All In One PC's (like the HP TouchSmart series) there is a rear cover that is under the desktop stand that can be removed and the hard drive is in a metal rectangle cage on the left side.
So, in almost all AIO systems, the hard drive is accessible by removing one or two panels off the back of the unit. RAM for these units will also be visible too.
2helpful
Remove hard drive from tower case gateway 815 gm
http://support.gateway.com/s/PC/R/4190/4190nv.shtml
Looking at the rear of the computer;
A) Two thumbscrews to loosen, then remove the Left Side Panel.
B) Two Philips head screws to remove for Right Side Panel.
(Designation of left/right Side Panels are looking from the Front, of the computer)
Pop the Front Cover off. WATCH the wires so they do NOT get disconnected from the motherboard!
Slide the right Side Panel back about an Inch, then lift out, and off.
Click on - Gateway Computer User Guide - in blue.
Now remove the 1 or 2 Philips head screws on the right side, that hold the Harddrive into the harddrive bay.
For additional questions please post in a Comment.
Regards,
joecoolvette
CMOS battery gateway t-1625
Remove the keyboard and the media button panel.
Remove all the screws from the underside of the laptop.
Remove the access panels.
Remove the hard drive.
There are three screws that holds the chassis together here (inside the hard drive bay). You won't be able to completely open the chassis but now you can use a flat blade (I used a small flat head screw driver) and pry the top and bottom pieces apart.
As I mentioned, you won't be able to completely take the two chassis pieces apart but you will now have enough clearance to access the CMOS battery to the right of the headphone jack (looking at the bottom).
I used a small flat head to pop the battery out. I then used long tweezers to place the new 1220 battery on the battery tray and reached around from the hard drive bay and popped it in with my index finger.
Put everything back together in the order you took it apart.
How do I enter bios on Gateway desktop 835 GM?
All of Gateway's desktops use the F1 or F2 keys to access to the CMOS setup. Turn off your PC, and power on the PC. Press the F1 or F2 key immediately in one second intervals when you see the initial screen displaying the BIOS.(Try F1 key first, if it does work try F2 Key) Hope it helps.
4answers
How to remove hardrive from ml3109
Turn the laptop so the bottom is facing up. Make sure you have powered the laptop off and have unplugged the AC adapter and battery. Near the part labeled E there are two small phillips screws. You would need to remove those and the tray at location E will pull out with the hard drive attached. There will be 4 screws(two on each side) holding the hard drive onto the tray, remove those and the hard drive can now be taken out. Reverse the steps using the new hard drive.
2answers
I need to re-connect the internal DVD drive in my daughters Gateway MX6428 laptop. She apparently dropped it and it no longer registers it's connected. We've taken all the panels off of the bottom. No...
How to Remove Replace and Install Your Gateway MX series MX6428 Laptop Hard Drive
1. On the bottom of your Gateway MX6428 laptop, find the hard drive door to access the hard drive.
2. Remove the Screws.
3. In this step, you will either need to pry out your Gateway MX6428 hard drive caddy, or simply remove the door.
4. Once the Gateway MX6428 hard drive is removed the laptop, you need to remove the hard drive caddy. There are usually four screws to remove from the caddy.
5. Simply Insert the new hard drive into the caddy. Place the screws back in. Install your new Gateway MX6428 hard drive.
Want to remove my hard disc... but.. I can get to and remove the 2 screws on the "inside" of the drive.. but.. the two screws next to the case are so close to the case I can't get to them. Am I missing...
The hard drive is secured to the frame and this frame needs to be removed to get access to all the screws holding the hard drive to the frame. The frame may have screws holding it to the case or accessed from the front of the computer after you remove the front faceplate panel.
1helpful
When I try to access the USBX-835-EGFS USB 2.0 Drive come back the message: E:\ does not exist. Error at page operation. What can I do to solve this problem?
You need to scan the drive with a very good ant-virus software such as Avira anti-virus, then you scan thoroughly. This should work but if it does not, you can try formatting it
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
