Video Cameras Logo
a
armando naranjo Posted on Jul 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sdr-b74301n is not turning on, there's power but I can't see anything on my tv
abdul rauf
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Video Cameras Expert 483 Answers
  • Posted on Mar 07, 2020
abdul rauf
Level 2:
Dedicated:
Answers
483
Questions
0
Helped
95922
Points
726
The video out point must check, if not getting use a best monitor connecting cable, not solved must open and check the signal outing component.
The time changes on my SDR B74301N DVR The time will not stay after saving
[ Work At Home For USA ]
honest online career from home Earns upto $550 to $750 doller by way of work is simple on web. i have made $28K only month via chipping away on internet. Its right way and easy home work maybe a piece adolescent can complete this movement on web and benefits.chek detail .... Www.Works75.com
1helpful
2answers
MY HITACHI SCREEN IS BLACK, POWER ON BLUE LIGHT BLINKS 4 TIMES
sounds like bad mainboard or power supply board most likely the power supply
I have a hitachi p50s602 that flashes a blue light code 6 times. any idea what it is calling out?
no power / dead unit / comes on and protects itself, power led may blink in 3 or 4 times cycles.
check/confirm sdr buffer ics are not shorted, if so, replace affected sdr pwb. The buffer ic are on the side of you set in the back once it's removed(cover).
4helpful
2answers
Problem with Hitachi P50H401 Plasma TV - Will not turn on. Blue light flashes 4 times ???? Plasma TV less than 2 years old will not turn on. The blue light continuously flashes 4 times
I have the same model, P50H401 and it developed the same problem two days ago. This set is 2 1/2 years old in service, being purchased in December 2007. The original manufacture date was October 2007.
The set was turned on and operating at the time and then promptly shut down by itself. The front blue LED power indicator began flashing four times in a loop or cycle.
The flashing LED sequence in this instance points to a problem with one of the following boards: PSU, X-Sus, Y-Sus or SDRs (there are two SDR boards, SDR-U and SDR-D, both are connected off of the Y-Sus board on the left hand side of the frame when rear facing). The set shuts down to prevent further damage to other boards or components.
I could power cycle the set but it would shut down after after a few seconds. Power LED would stay solid, I could hear the PS relays switching, and audio would output through the speakers. Then as the screen was just about to illuminate, the entire set would just shutdown. The blue LED would again go into the 4X flashing sequence.
I could not visually detect any signs of severe component damage on the main PS board. The two large electrolytic capacitors which have been mentioned as problematic in other threads seems fine. The where slightly raised on the top surface, but not blistered or completely blown open.
The only indication of component damage that I could detect visually was on one of the small surface mounted ICs on the SDR-U board.
Through reading other posts on this site, I learned that I was able to remove the suspect SDR-U board and then re-power the set. Doing this proved that the PS, X and Y Sus, and the SDR-D boards where o.k. The PS held, and the lower half of the screen illuminated. (I would only do this for as brief a period as required to determine if the the other boards would function and the screen would illuminate. Do not pro-long operation in this state so as to not cause further damage.)
It was somewhat difficult to locate the correct SDR-U board. My local service rep did not have one in stock, and the Canadian parts distributor was also out of stock. They estimated 10 - 14 business days to order one up from the U.S.A. (Hitachi closed their consumer electronics division in Canada back in 2009.)
By chance, I checked with another service rep in an adjacent town. He had a board for the P55. We did a visual comparison on the two boards and determined that it would be compatable.
The easy part was removing the defective SDR-U board and installing the replacement. The hard part was re-alinging the three ribbon tabs into the respective connectors on the SDR board. Be careful with these ribbons. The other end of each is fused to the plasma panel screen, so if you damage them, your screen is rendered useless.
I initially had the same problems as others have posted with having black or gray lines on the screen when the SDR-U was replaced. After gently adjusting the position of the ribbons as they are seated in the connectors, the lines disappeared. This was a slow and frustrating procedure, but it worked, Be patient.
2answers
I got new power supply for my tv and still doing same thing, blue lite stays on only way to turn of is up plug it its a hitachi 50s601 plasma little more then 1 yr old, i talk to a tech and he maybe a...
blue light on is a good indication that the power supply is up not always but not replanding to commands is always the main board the cpu and commands are not talking
My hitachi P50H401 will not turn on. No sound no
check your sdr boards. you can test them with a multi meter. they are known for going bad. what happens is the two caps by the output go bad on the power supply and they make the sdr boards burn out. you can replace the two caps and save lots of money. then please check out this web page http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
This web page has info about repairing these. The 4 flashing lights maybe the x sus or the y sus but it's still a good idea to check the sdr boards since its a common failer. I had one tv with a bad sdr board flash 3 time and another set it was flashing 4 times.
2answers
Tv turns on for a few seconds then the picture and sound turns off and the blue power light just blinks
It will do the same thing, until a repairman comes out, and services the TV set...
Symptom: No power / Dead Unit / Comes On and protects itself, Power LED may blink in 3 or 4 times cycles.
Cause: Check/Confirm SDR buffer ICs are not shorted, follow link to check. If so, replace affected SDR PWB.
That's what MY Hitachi service portal says...
Do you have one?
It's kinda like a crystal ball or magic carpet....not many people have one, but Hitachi techs do....
Eeenie Meenie Chili Beanie the spirits are about to speak
3helpful
Hitachi P50H401 no power but when i replace sdr-u board
I just solved this problem on my TV. I replaced my SDR board and had the same lines. I reseated all of the connections, and gently pushed them in until I felt a slight pop. once I felt that I gently pulled on them to make sure they would stay in place. if they did I closed the locking lever if not, I repeated this action. then simply turned the TV on and all of the lines were gone.
Top Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Video Camera Expert? Answer questions, earn points and help others
