The water still works on the door. I tried a blow dryer on the line, ice is now producing, however it is very slow.The water still works on the door. I tried a blow dryer on the line, ice is now producing, however it is very slow.
Is it frozen? Is your line kinked somewhere? Is your water valve turned on? Is your switch in the on position?Is it frozen? Is your line kinked somewhere? Is your water valve turned on? Is your switch in the on position?
You can't post conmments that contain an email address.
Check to see if your water line is connected on both ends and that the valve is open on the end connected to the water line. the water line may be frozen inside the fridge
Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
How can I thaw a frozen line?
