Tried that-doesn't work. "Control Lock" comes on and will not go off although I hold the "end of cycle" key for 3 seconds.Tried that-doesn't work. "Control Lock" comes on and will not go off although I hold the "end of cycle" key for 3 seconds.
You can't post conmments that contain an email address.
Please make sure that you've removed all of the lint from your dryer prior to every cycle. Next, try to see if the varying the load size effects whether your clothes are heated or not.
If all else fails, please schedule an inspection by Whirlpool by calling 1 (866) 698-2538. Thank you.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
you may have a bad motor control board they are very expensive. There are screws on rear top panel and the top slides off. The board is located on the left side. If you hear a click when you start it then there is a relay got on board.
Yes, there is a child safety control on the Whirlpool Duet. The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. The following link explains how to turn the feature on/off:
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
You said, you replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum
light won't shut off even with door closed. Dryer will not work but all
panel lights function normally - UNTIL you press start. Dryer just
beeps and doesn't work. When I tried the troubleshooting solutions, the error 6E comes up. What does this mean?
This sounds like the reason your bulb went out was more than just a bulb normally dying! There is a short, or in that socked or the switch or it affected the the control panel too!! This sounds like a hands on diagnoses job!
