Question about JVC Televison & Video
Television model JVC LT-32N 50A LCD does not turn on ,it shows only red light on panel what can be the problem?
6ya staff
SOURCE:
Anonymous
  • 60 Answers
SOURCE: Remote control for JVC TV stopped working
1 if this new ordere it is exacly the same that should work when i say exacly that must have only the same button on it
2 you should try to take off the cover to that old remonte and try to clean the taste and then the change battery clean suport to battery wash your rubber taste and put all togheder and should work if that not hapened the problem it is from inside tv
and to that new one see if you have a shift buttun on it and push that or push tv button and try again should work
Posted on Dec 10, 2008
Jim Krause
  • 1779 Answers
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Posted on Feb 04, 2009
Anonymous
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Posted on Jul 21, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: JVC LCD have sound no picture
it can be either the backlight inverter board or the power supply module is not supply 24vdc to the inverter board.
Posted on Oct 31, 2009
Anonymous
  • 3 Answers
SOURCE: i have the same problem with my tv.
take back off lie flat
where the hd leads go into that board remove the screws at the top and bottom as its one long unit top to bottom
unscrew metal shield as well
remove all cables from board 2 ribbons are locked and require clipping down then ribbon removes
flip board over remove metal can to expose board notice 2 TSOP chips at top look att the pins one should look dull and not shiny
to fix i used heatgun a quick blast on pins sorted problem out
mask off board and chip around with metal etc... to not damage board.
Posted on Nov 15, 2009
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Tip
JVC LT-32X575 LCD TV Manual Download
Download JVC LT-32X575 LCD TV Manual
Would you like to review the features of the JVC LT-32X575 LCD TV ?
Have you lost your JVC LT-32X575 LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC LT-32X575 LCD TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC LT-32X575 LCD TV documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | JVC LT-32X575 32 in. HD-Ready LCD...
Tip
JVC LT-26X585 LCD TV Manual Download
Download JVC LT-26X585 LCD TV Manual
Would you like to review the features of the JVC LT-26X585 LCD TV ?
Have you lost your JVC LT-26X585 LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC LT-26X585 LCD TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC LT-26X585 LCD TV documentation.
I hope that helps.
on Jul 03, 2010 | JVC LT-26X585 26 in. HDTV-Ready LCD...
Need codes for JVC television model JVC LT-32N 50A LCD
0007 0018 0075 0103 0123 0154 0163 0170.
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 03, 2015 | JVC Televison & Video
Tip
JVC LT-32X585 LCD TV Manual Download
Download JVC LT-32X585 LCD TV Manual
Would you like to review the features of the JVC LT-32X585 LCD TV ?
Have you lost your JVC LT-32X585 LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the JVC LT-32X585 LCD TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the JVC LT-32X585 LCD TV documentation.
I hope that helps.
on Jun 29, 2010 | JVC LT-32X585 32 in. HDTV-Ready LCD...
JVC 32 inch LT-32DY8ZJ T turns on...shows green light....then turns to standby then back on then off again. Can this be repaired?
Good day..
That problem is usually cause of bad capacitors on the power supply section..
As you stated your TV works fine and after a minute the red light comes on...
That symptoms is cause of bad capacitors..Normally bad capacitors can check visually if the capacitors look like leak/bulged on the top that is the indication of bad one but not all bad capacitors are bulged some are not so in that case you have to used a special meter called capacitance meter..
This is the sample picture of bulged capacitors:
Dec 05, 2011 | JVC LT-32X575 32 in. HD-Ready LCD...
JVC LT-32P679 Blinking Power Light, Automatic Shutoff
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Mar 17, 2009 | JVC LT-32P679 32 in. LCD TV
I have a JVC 42" LCD plasma flat panel the screen went an orange-red plaid look..now the screen looks as if its shattered....HELP
Sorry but if it looks shattered....it is shattered.
Put it on Ebay and buy a new TV as the LCD Panel will cost you more than this model currently sale for.
Jan 24, 2009 | JVC LT-42X579 42 in. LCD TV
Televison & Video Logo
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
