When i turn on the camera, new batteries r in, it still says "change batteries", and shuts down. pls. help! it's very annoying.
Put batteries in very carefully - not bouncing them in. If you get the 'change the batteries message' then open the battery cover turn the camera a little gently to reposition the batteries and hopefully it should go away. Test your charger too ... is it charging? is it the same thing with non-rechargeable batteries?remember Batteries don't work well when cold this could cause the camera to shutdown. It might also be that the auto shut down setting is too short unless it is shutting down while you are actually shooting.make sure you are using the correct battery type and match.clean the contacts in the battery compactment.hope this helps
