Put eggs in cold water, then boil, let sit for 20 minutes, then rinse in cool water, not ice
The grey around the yolk of the egg when hard boiled is due to the sulfur in the yolk. Cook the eggs a little slower, slow simmer, and add a little vinegar and salt to the cooking water. I have also found that we all have the tendency to overcook hard boiled eggs which also helps create the grey around the yolk. I have found that eggs simmered for not more than 12 minutes are hard boiled but don't have as much grey.
SOURCE: Have the Nordicware Egg Cooker
Welcome to FixYa! If you are happy with my solution and are able to get what you need, I'd appreciate a rating so that I can continue to improve my service (and make my boss happy). Now to your issue.
Nordicware does not publish their manuals so I am providing you with a number where you can get a users guide mailed to you free of charge.
Call their consumer services department at 1-877-466-7342 8:00am to 4:00 pm CST
and we will be happy to send you the directions in the mail.
I hope this solution helps you enjoy your egg cooker for years to come and thanks for using FixYa!
SOURCE: hard cooked eggs
Hi, You can cook up to 12 large size eggs at one time in this steamer. Fill the base to the medium fill line, place the eggs over or close to the steam holes, and cook for approximately 35 minutes. If this helps, please rate this answer. Thanks! Hal
SOURCE: We have lost the water measure that comes with the
5 1/4 tsp.... my machine will only do 7 at a time though... so you may have to alter it a bit. and dont forget to poke a hole in the top end :)
SOURCE: I have a Petra Mini
I could not find a User's manual for your exact product , but did manage to find a few for similar ones. Hopefully the instructions will be close enough to be useful.
Here are the links to the various different User Manuals:
http://docs.google.com/viewer?a=v&q=cache:IWFMsvYp1AMJ:www.aroma-housewares.com/manuals/AEB-917_InstructionManual.pdf+egg+boiler+manual&hl=en&gl=ca&pid=bl&srcid=ADGEESj6mslVwJ8oezvS13mer1WGaPkzHeKwaPKDgqxf-Dh5PlT4EGi69hg4eEz37UlIftMNgWQbpudbZjX0gejyQGG4p9Q60JkjC3NSVbEmohEMJyFz96IM4G-TwRapnay703aq9NsN&sig=AHIEtbTSKBHVQUNl-Z49yDFjBFDU2VjoFQ
http://docs.google.com/viewer?a=v&q=cache:I-QT8gkmlTgJ:www.hyvox.com/support/userguide/hi377.pdf+egg+boiler+manual&hl=en&gl=ca&pid=bl&srcid=ADGEESgAhORjQbcPvI3y6nd7UhXBECd0G9s7tBK3Az6gZux0nWqP6p6qkQpDnV5gsKWzIs8AJgd7j77G6LXwnaBJVfvqbovpCbyk4jAtUcIJgXFbKkL6LSyvozYQiWRFD9AjqfXGPjJT&sig=AHIEtbRM9TdyMYkP-rh5Z4WeR8GtUAkD_Q
http://docs.google.com/viewer?a=v&q=cache:WnS-WXSh9YQJ:www.stellarcookware.co.uk/images/brands/stellar/ranges/stellar-electricals/products/automatic-egg-cooker-care-and-use.pdf+egg+boiler+manual&hl=en&gl=ca&pid=bl&srcid=ADGEESjkvYYeP9uDBrTwuJt-Ij7ZFF-WwqEHqXcSYbDGW8GAmTq1Rk8G-SssmQWC93fLuBfs5hLNyKq-Cklb2zGQ2HqzeGengKbDz9jJxpQfvlyJFEQhXOFp1Ki8V-VPif7iw4js6xPS&sig=AHIEtbRK2R0i_5Jtz6P6b7_F7Guq2mAmiA
http://docs.google.com/viewer?a=v&q=cache:eF_rrUWIf8MJ:www.powastation.com/instruction%2520manual%2520downloads/E%2520SERIES%2520PS7EG01%2520IB.pdf+egg+boiler+manual&hl=en&gl=ca&pid=bl&srcid=ADGEESh2baC5BNulTSDz9XN4EEocFieguqGOhOuLkoW3VEQ9jI-qFMxk09tQpP31BEtm2OX3aMyTkN4AgAKusje1tBpRT16-2kCEN_HIy5wdBSsDAUG5Y0DukEAktmoaPJTqkS4HCHNg&sig=AHIEtbSXv4NpRCghF6UnJoysWrfGSVe9Vg
To view the Owner's Manuals with Operating Instructions just use your mouse to click on each of the links, which is the underlined and highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
SOURCE: my friend bought me a hyundai egg cooker(plu
Ignore the instruction manual. Instead look at the measuring cup that comes with your Hyundai PLU 247959 (produced and sold under license by Poundstretcher).
On the side of the measuring cup, you can see three clusters of marks:1. 25 to 40 ml for soft-boiled eggs (symbol of egg with two horizontal lines)2. 45 to 60 ml for medium boiled eggs (symbol of egg with one horizontal line)3. 65 to 80 ml for hard boiled eggs (symbol of egg)
Egg boilers are based on the principle that the larger the volume to be heated is, the less water is required. In other words, you will need to add less water for boiling seven eggs, and more water for boiling one or two eggs.
Which means that for seven eggs to soft boil, add 25 ml; and for one egg to soft boil, add 40 ml. If you look at the markings, you'll notice that on the vertical line between 40 and 25 ml, there are seven equidistant horizontal lines, each showing the amount of water required for the various quantities of eggs.
One egg = fill with water up to the 40 ml markTwo eggs = fill up to the mark below the 40 ml markThree eggs = fill up to the second mark below the 40 ml markFour eggs = fill up to the third mark below the 40 ml mark etc, untilSeven eggs = fill up to the 25 ml mark
Medium boiled and hard boiled eggs are measured in similar ways. Works every time for me. Nice little egg boiler, by the way.
Here are the amounts in teaspoons of water
12 tsp = 1/4 cup
