Question about Westinghouse Televison & Video
My Westinghouse tv comes on but remote wont do anything except off/on
I have an onn remote for a westinghouse tv it turns tv off but not on and will not change from HDMI1 to anything else anytime you move it to TV or HDMI2 is goes back to the HDMI1 screen
For the universal remotes, there is a code that you have to put in to tell the remote what codes it is to send to the TV. Perhaps you have the wrong code in the remote. The other choice is it may not adequately support your TV. This code is on a paper that came with the remote. Try another code and see if that makes the difference.
Mar 06, 2017 | Westinghouse Televison & Video
Does the lamp in westinghouse lcd flat wear out and prevents remote from turning on tv?
If the unit comes on manually but not with the remote, first try new batteries in the remote transmitter. There is an LED in the remote receiver PCB, but more than likely the issue is with the transmitter..
Jul 24, 2014 | Westinghouse Televison & Video
Why can`t I control on off and volume on my 39 in westinghouse tv model no dw39fiyi with my cable remote?
It sounds like your remote isn't programed to your T.V. You should be able to use 991 to complete this if you don't have the booklet.
Apr 22, 2014 | Televison & Video
Westinghouse 32' flat screen tv wont work with cox cable receiver
Hello
You haven't stated the type of signals that comes with your co-axial cable; analogue or digital. Anyway, you have to retune the TV after connecting it properly with Cox-Cable receiver with TV.
Feb 23, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse wont connect to cox cable receiver
Hello
You ahve to setup the cable receiver to your Westinghouse TV. For more details, try these links to download the setup proceedings. I hereby attaches the links that might help you.
If you feel any difficulty in downloading the same, inform your email address to me by Fixya comment. I'll send a copy of the setup manual to you by return mail.
www.cox.com/hr/support/dc/docs/HDUsersGuide.pdf - United States
www.cox.com/support/cable/pdf/userguide_1.3.pdfSimilar
http://www.dataentryjobs.us/67948.html
www.cox.com/hr/docs/channel_lineup.pdf - United States
Feb 23, 2012 | Westinghouse Televison & Video
I played a dvd and now can't get the tv to come on. How do you switch between dvd and television? This is a Westinghouse DVD LCD combo television.
on the remote there are various button at the top to control the functions. these include tv dvd cable etc.
When the remote is set on tv all the functions on the tv work together with the functions of dvd such as play stop etc.all except power channel up channel down etc.
THE REMOTE MAY JUST BE SET TO DVD JUST PRESS TV AT THE TOP OF THE REMOTE OR YOU MAY NEED TO SET IT BACK AND THE PROBLEM IS FIXED!!! THE USER MANUAL SHOWS YOU HOW TO SET IT.
Feb 27, 2010 | Televison & Video
Westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Feb 16, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
TV code
Philips universal remote , it have code for that tv..
http://www.urc.philips.com/
May 23, 2009 | Westinghouse SK-32H240S Television
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
