Home Logo
Posted on Sep 06, 2009
Loose Toto toilet seat
Toto toilet seat not secure. How to tighten toilet seat?
Anonymous
Level 1:
  • Contributor 54 Answers
  • Posted on Sep 14, 2009
Anonymous
Contributor
Level 1:
Answers
54
Questions
0
Helped
26580
Points
80
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
  • Sheila Vasquez
    Sheila Vasquez Mar 02, 2014
    There are only plastic covers at either side, no nut.
New toto promenade toilet tank lean forward and plumber put putty tape where it has contact with tile and bottom of toilet base.. Also alot of play in elongated toilet seat? please help
Tighten seat nuts, they are underneath, you will have pop open the tabs covering seat screw to hold it. If the toilet was level before tile saws installed call tilers back. The closet bolts may have come loose or closet flange is broken.
Feb 27, 2018 • Toto Home
Toto toilet seat slides to side
you have to tighten these from the bottom of the bowl...use open end wrench or cresent to do
1helpful
I have a Toto toilet and am trying to replace the old seat. BUT the bottom is a solid piece and makes it impossible to access the seat bolt for tightening. I began loosening the seat bolts. now I have a...
hi there
this type of seat has rubber gromits that squeeze up when you tighten the screw.if it wont tighten up the gromit may have failed and would need to be replaced.
good luck
1helpful
2answers
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
The toilet seat is super loose and I am unable to tighten.
reach under and hold wing nut or nut while tightening screw if plastic screws are stripped any hardware or home store carry replacement screws
1helpful
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Loose toilet seat
If the screws don't tighten the either the screw threads are stripped or the attachment nut is stripped. Take the screw and nut to any hmoe repair center and get new ones. remember don't over-tighten then screws as this will crack the unit.
The toilet seat on my TOTO toilet has come off. Has something broken that I can repair or do I have to buy a new seat?
are you sure it is broken or the screw has come loose check it out again does not break very easily
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
