SOURCE: hi, i need to know
The Bluetooth device that your Droid 2 is scanning for must be in "Discoverable" mode:
1. (If not already off) Turn it off by pressing and holding the call control button. Hold it until the indicator glows red and emits a sound.
2. Now press and hold the call control button for five seconds until the light begins blinking red and blue, then release the call button.
3. You may now rescan for your Explorer 232 on your Droid 2 and Select it when it shows.
4. Enter "0000" as the passkey if you are prompted for one.
SOURCE: How to rewire transformer that was torn loose from
google the number that is on it. If it has one. Go to mouser.com and order new one. As long as the specs are close it should work.
1) Turn the power off.
2) Remove the printer cover.
3) Remove the ink roller by turning it counterclockwise and
pulling it upward.
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place.
5) Put back the printer cover
