After turning comp on screen reads "configuring updates 3 of 3, 0% complete" then shuts down and tries to restart, won't boot up.
After running a diagnostic test, got this Msg: IDE device failed; Blank media or no media is present in optical drive.
SOURCE: error code 0f00::065d msg:IDE failed
The error code says that "Windows will not boot, Not even in safe mode". Am i right...
Get a new Hard drive(HDD) and connect it to your pc and load the Windows Operating System. Or again try installing a new copy of Windows to same hard drive. Hopefully it should work.
Or else do one thing . First you do this - Go to BIOS setup. To do this restart your PC and keep on pressing the del key or F8 key. The system will automatically goes to BIOS mode. change the configuration settings i.e., disable storage devise. If it's enabled then your pc will not detect Hard drive. Thank you
