Computers & Internet Logo
Posted on Sep 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
White line on screen easynote mv35-202
I have a problem with the screen on my easynote mv35-202. A white line has appeared about three inches from the right hand side of the screen. It changes colour from red to blue depending on what angle I tilt the screen. How can I remove this?
Anonymous
Level 2:
  • Expert 22 Answers
  • Posted on Sep 07, 2009
Anonymous
Expert
Level 2:
Answers
22
Questions
0
Helped
71489
Points
145
Replace the LCD screen. Its problem with the LCD panel.
1helpful
White spots on sony bravia 32" S series
what is the cause for the televisions screen to get white spots that spread
One inch white line when booting slowly becomes solid
If you'r not expert fixing laptops send it to repair shop to check screen cable it might be screen data cable problem like it loose or need replacement if this not the problem then Ohhh time to change the screen...Good Luck
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
It looks like that the ribbon cable connected on the logicboard to your screen is the one that is causing the issue. What you should do is to have it checked by the manufacturer (Gateway) if it still has warranty and if it doesn't have you should take it to a nearest service center that would be able to open the computer and check if the ribbon is loose or damage.
A white line across my screen
A chip died in the LCD screen. Definitly take it back or contact the manufacturer for a warranty replacement.
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
WHITE LINES
i have the same problem
White arched lines appearing on dark/black screens.
it sounds like you are seeing the vertical retrace for all three colors together (white). Its possible that all three screen adjustments (red, green, blue) are off, but I suspect a problem with the screen power supply.
there is also a recall on this set
http://esupport.sony.com/perl/news-item.pl?mdl=KP51HW40&news_id=24
Apex 43 inch tv
Convergence is when you aim all three of the projectors, your tv has three, so that the images they produce all line up with each other. This usually doesn't generate a white line across the middle of the screen though, there is a button on the front panel of your set that automatically converges the three projectors, you can try using that.
Grand Canyon Tech
Grand Canyon Tech
