Clean the carb. Change the plug. Get some start fluid but use sparingly. Run the water (pull the washer trigger) while you are trying to start the engine.
The wiring diagrams in the Haynes book should show the washer pump circuit? Often the washer pump shares the same fuse as the wipers. You could pull off the electrical connector for the washer switch, or the multi-function switch if so equipped, and check for voltage on the pump wire going to the switch, key on. Then check if power going out of switch to the pump-key on and pump switch on. If power on both, the wire from switch to pump must be broken. Run a new wire. If power into switch but none out-switch is bad. If no power into switch for the pump, may have to keep looking for a bad fuse or the wire from fuse panel to the washer switch may have a problem. Hope this helps, good luck.
Long Drain. Either yall have something in the pump or the pumps filter needs cleaning out. LD indicates this is a LG washer. I have yer LG washer service manual right ova HEAH. This is my blog link to all my LG manuals and notes. Have a good un.
Use a s.o.s pad to remove mold there will still be staining but it will gey the bulk of.Now to get rid of the smell ( this has been a mixture I have used for about ten yers works every time) put the washer on hot heavy wash start when done filling drain what you want to do is make sure the water is the hottest it can be. now start washer again on hot wash when you see water in bottom of tub stop machine to open door ADD two cups of dish washing power( brand does not matter I tell most people to buy cheap stuff at walmart) start machine let it run till you see powder disolve then stop washer and add 1 cup bleach. let unit go through complete cycle..If your washer has a clean cycle use that instead of the heavy or normal cycle. The most I ever had to do this treatment was 2 cycles and it worked every time.Note all front load washers the door must be left open to pervent odor/bellows should be wiped clean after each use/and a good cleaning at least once a month. anyhow if this helped please vote if you need more help please ask
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
