Whirlpool Refrigerator service center Hyderabad. the efficiency of your equipment increases extensively if; the servicing or changing obligations can be finished via Our service center technicians. Your Fridge may not work properly. more of people purchase Whirlpool Refrigerators. If you have any problem with your whirlpool fridge then visit us we have the topmost service agents to fix your Refrigerator issues at your doorstep http://aktechnoservice.com/whirlpool-refrigerator-service-center-in-hyderabad
Have you changed your filter for the water/ice? If, not this can be the problem. We recently had this issue with our Frigidaire we were leaking water under the veggie bin so badly even leaking on the floor until we finally changed out the filter for the ice/water machine. I hope this solves your problem.
SOURCE: Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
SOURCE: frigidaire frs26zthb3
icemaker is iver filling and running down through the freezer, some of the water runs out into the floor since the door gasket does not provide an water proof seal just an air tight seal
the ice maker can be adjusted, remove the cover off the frount of the icemaker and back the screw on the right side so that the indicator in the middle is twards the minus sign and you need to clear the frozen water out of the freezer drain pan so it can go to the drain pan down at the compressor
it might take a few adjustments on the ice maker to get it right
SOURCE: the coils are frozen solid in freezer behind back wall
frozen coils not always means freon problem. low air flow across evaporator coils could cause freeze up. if door is opened and closed an abnormal amount could cause a freeze up or even something pushed up against the air intake in the refridgerator. i would thaw it out completely and restart it, theres a chance it was nothing major. good luck
SOURCE: Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
SOURCE: Water leaking from behind ice chute door & freezes under ice bin
You will have to remove the unit and access the rear of freezer. Check that the filters are not plugged as well as drain.
