Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
Posted on Sep 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My SOny Projection HDTV makes buzzing noise when turned on
Each time the TV is turned on, it makes a buzzing noise. WHen the TV is turned off, the noise is still there until the TV completely shuts off after approximately 1 minute.
Anonymous
Level 2:
New Friend:
  • Expert 157 Answers
  • Posted on Sep 07, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
157
Questions
Helped
47057
Points
470
If tv is a dlp you have eithor a bad color wheel or bad fan.would need model number to research it more
There is no picture when I turn the TV on, the red lamp light under the power button is blinking, when you turn the tv on, it goes off for 60 seconds, there is a ringing buzz every 20 seconds, then the tv...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is xl-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click-48173.Have a blessed one!
5helpful
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Buzzing noise
COLOR WHEEL OR COOLING FANS
KDF60-60wf655 lamp relacement problem
Make sure you have the lamp seated correctly
If you used a non sony lamp it may not be compatible
remove the lamp and look to see how the two connectors line up
they are the most important
Buzzing/screaching noise when turned on, standby light blinks and then lamp light blinks
It sounds like a bad lamp. Replae the lamp firts, but there is a chance you have a bad lamp driver also.
Sony WEGA
Hello Khaoz99,
You have a bad lamp. Thats it. The buzzing noise is the ballast firing trying to re- start the lamp.
List Price $200.00
Best regards
circuitcity
Samsung LE26R74BD plasma sreen tv sound problem
To Fix.. The Buzz.. The noise comming from one of the Board Inside. Open it and see..Or call a tech..
RezaKhan
RCA 56 projection
Does the buzzing come from the speakers or the back...turn the volume down.. is it still there?
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
