Toll-Free +1-866-231-0111 Brother printer receiving the 'Drum error'? Then, you have to clean the corona wire on the drum unit of your printer immediately to resolve the issue. Brother Printer users often face this common error but before calling the company for an instant tech-support, trying some steps can help to resolve the issue. Have you been facing the issue for quite some time and keep asking yourself How to Fix Brother Printer Drum Error? Then we here have some solutions for you. Follow the given steps and DIY resolving the error and see whether it's gone or not.
Step 1 Fix Brother Printer Error Drum
· Slowly open the lid of the printer and remove the drum unit
· Also, remove the toner cartridge assembly
· Keep a piece of paper on which the parts can be kept to avoid spilling of the toner
Step 2 Brother Printer Error Drum
·If the error Drum still persists, you have to replace the drum assembly.
·Consider resetting the Drum Counter
·Press the 'Menu' option> click on the 'Machine Info'> now click on 'Reset'
·Press Ok
·Now Press 1 to reset the drum unit counter
·Press Stop or Exit when
Brother Printer Customer Care Number +1-866-231-0111
If the mistake occurs, call for instant assistance at the Brother Printer Customer Care Number +1-866-231-0111. We are a 24 * 7 group of well-qualified and experienced engineers. We are willing to help you with your toughest printing mistake. Our techies strive to provide analyzed responses to all inquiries linked to the client
SOURCE: how to reset drum counter for brother hl4070cdw laser printer
When you replace the drum unit with a new one, you need to reset the drum counter by completing the following steps:
"Reset Parts Life".
SOURCE: Brother MFC 8660DN
Pull the drum/toner out and look into the machine, at the wall on your left. There's a little plastic lever there that pivots to detect a new toner cartridge. Sometimes the lever gets sticky; wiggle it to free it up. If you feel brave enough to remove the outside cover of the machine on that side, you can put a dab of grease on the lever's pivot.
SOURCE: HL-2170W Laser Printer: Brother printer hl2170w drum light...
drum light ended need to be replace drum.
SOURCE: message "toner or cartage or drum error of brother laser printer"
replace both drum and toner .
