When I say 'battery lid' I mean the plastic slide that covers the battery compartment. I've checked the inside of the lid and the battery section and nothing looks broken. What can/should I do?
SOURCE: electric sliding door
pull the radio fuse under the hood in the relay/fuse center. this will clear the memory for the door. the fuse needs to be removed for 20 seconds
SOURCE: outside sliding door handle?
Yes. It is a difficult job, but not impossible. The hardest part is actually removing the interior door handle. Here are the steps.
re-assembly is the reverse of the removal
SOURCE: The sliding door handles of my 1998 Toyota Sienna have both broken.
I replaced both of my sliding door handles this weekend. It was actually pretty easy. Cheapest I could find the handles was a little over $70 each. The interior panel is held on with one screw and 10 nylon clips. The one screw is in the cup holder. Put you hand in the cup holder and push out at the bottom. It pops right off exposing the one screw. I started on the clips from the top at a corner. Seemed to be the easiest place to slide a screw driver under. Once I got the screw driver in, I started working my fingers under the panel. The clips run mostly along the top and bottom about 6 inches from the edge. I made an effort to apply the force as close to the clips as I could to reduce flexing the panel. Once I got the first clip to pop out the other followed pretty easy and the panel lifted right off. Carefully peel back the plastic barrier. The exterior handle is held on with two 10mm bolts. Connecting the short cable was pretty obvious once you could see everything. Now I have to teach everyone to open the side doors very gently! Hope this helps.
SOURCE: Rearview mirror fell off windshield! Not broken...
the mirror should simply slide over the metal mount (button) that is glued to the window.
loosen the set screw on the mirror mount...
hold the rear view mirror mount on the glass just above the metal mount (wide end of plastic opening facing down)
slide it into place...
secure it by tightening down set screw you loosened earlier.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: could not open driver side manual sliding door in my 2003 Sienna
need to remove inner panel.. be careful not to break panel... ck latch seems broken.. o
