Question about Garden
Mower will not start. Replaced spark plug, air filter and fuel filter. Checked oil. Fuse good. Makes the same sound whether the spark plug wire is hooked up or not.
  • 1 more comment
  • pipeter29902 Sep 08, 2009
    Craftsman mower model 917.270510 14.5 HP B&S engine model 287707, type 1255-E1
  • Anonymous May 11, 2010
    Could you give us a clue - machine make/model, engine make/model?? :-)
    What make mower year ect... I can help:)
    New Friend:
  • 62 Answers
The key word here is the sound, engine must have compression, put your hand over the carb and try to start, if it trys to **** your hand then you should have enough compression, if it doesnt then you probably have a broken valve- hope that helps
Posted on Oct 23, 2009
I have a cub cadet 54' zero turn mower I changed the oil. Oil filter ,air filter, gas filter plugs, put a new battery in it too but it still wont start
In order to have combustion you need oxygen, an ignition source , and fuel to burn. It sounds like you have your oxygen because that's at ambient air pressure and you have a clean new filter. New plugs is good but you might spark test the plug to make sure you don't have a wire problem and that spark is actually making it to the combustion chamber.(also make sure your spark plug is gapped correctly). And if everything checks out with the spark plug i would move on to checking the fuel supply. With the fuel supply it could be a number of things the Kawasaki engine that is on it has a carburetor so it could be a float sticking or a needle valve plugged also.
Oct 11, 2013 | Motorcycles
Type your problem for a solution...mowing for 10 minintes stoped to ceck blades started mower blue smokeout exhust. stoped mower checked oil will not start checked plug ,filter carbie and control lever
to check blade you tilted the mower and got oil where it should not be.
exhaust will clear out, check all controls to see if the spark is still there, allso a compression test check out a lot of problems. if it is low ,under 60 ,
just check the basic the three things needed to run- compression,spark,and fuel. always check things with the spark plug wire pulled of the spark plug. good luck
Jan 03, 2012 | Garden
How do I get my lawn mower ready for spring time use?
This is what a "General service" looks like at www.arcolawn.com
  • (Mower 2 cycle GS)
GENERAL SERVICE:
1. SHARPENED & BALANCED BLADE
2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS
3. REPLACED SPARK PLUG
4. FLUSHED FUEL SYSTEM
5. CLEANED CARBURETOR HOUSING
6. LUBED CABLES
7. CHECKED OIL SEALS
8. SERVICED AIR FILTER
9. CLEANED EXHAUST PORTS
10. TESTRAN & ADJUSTED.
  • (Mower 4 cycle gs)
GENERAL SERVICE 1. SHARPENED & BALANCED BLADE 2. REMOVED BLOWER HOUSING & CLEANED COOLING FINS 3. REPLACED SPARK PLUG 4. CHANGED OIL 5. FLUSHED FUEL SYSTEM 6. CLEANED CARBURETOR 7. LUBED CABLES 8. CHECKED OIL SEALS 9. SERVICED AIR FILTER 10. TEST RAN & ADJUSTED.
  • (rider tuneup)
Tune up
1.TIGHTENED ENGINE MOUNTING BOLTS
2. INSPECTED BOTTOMOIL SEAL.
3.TEST GOVERNOR OPERATION & ADJUSTEDRPM'S.
4.CHECK SHAFT BEARING.
5.REMOVED BLOWER HOUSING &CLEANED COOLING SYSTEM.
6. REPLACED SPARK PLUG
7.CHANGED OIL.
8.REPLACED OR CLEANED AIR FILTER.
9.ADJUST FUEL/AIR MIXTURE & SPEED LIMIT SCREWS.
10.REPLACED FUEL FILTERS AS REQUIRED.
11.CHECK FUELLINES, VALVES, & CLAMPS.
12.INSTALL FRESH FUEL IN GASTANK.
13.SHARPEN BLADE(S) & CLEAN UNDER BLADE COVER.
14.CHECK DECK, EXAMINE BELTS, PULLEYS.
15. EXAMINETRANSMISSION/DIFFERENTIAL FLUID LEVELS,
16.CHECKGREASE FITTINGS, WHEELS, WHEEL BEARINGS, HEIGHTADJUSTER.
17. CHECK CABLES & CONTROLS ADJUST BRAKE &CLUTCH.
18. CHARGE & TEST BATTERY. (IF EQUIPPED).
19. TESTSAFETY SYSTEMS.
20.REMOVED CYLINDER HEAD & CHECKEDCYLINDER FOR WEAR/DAMAGE. CHECKED ROD BEARINGPLAY. 21.CHECKED VALVES FOR PITTING, WARPING, CARBONBUILDUP & SEATING.
22.CHECKED VALVE STEM CLEARANCESFOR EXCESSIVE WEAR.
23.CLEANED CARBON BUILDUP FROMCOMBUSTION CHAMBER.
24.MACHINED HEAD FLAT.
25.CHECKEDTIMING KEY FOR DAMAGE.
26.CLEANED OR REPLACED POINTSAND CONDENSER (AS NEEDED).
27. SET TIMING. ADJUSTEDMAGNETO AIR GAP.
28.CHECKED THROTTLE SHAFT FOREXCESSIVE WEAR & REPLACED IF NEEDED.
29.DISASSEMBLED& CLEANED CARBURETOR. REPLACED DIAPHRAGM, NEEDLE &SEAT, NEEDLE VALVES ETC. AS NEEDED.(see carburetor section)
I hope this helps! get parts for the service at a dealer like www.arcolawn.com
Feb 14, 2011 | Garden
Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Jul 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
2008 Cub Cadet LT1042 Won't Start
If there is a fuel cup on the bottom of the carb take it off and clean it out real good. Take the fuel jet out and clean out the little hole by blowing it with air compressor or a real fine wire.The fuel jet is most likely the problem.
Jun 21, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Dec 22, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
104 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
