Watches Logo
Rosemary Sanders Posted on Jul 22, 2019
1884 gingerbread clock swings evenly for about a minute in good time then I hear a click up inside and pendulum stops dead
gwyn907
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Aug 21, 2019
gwyn907
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
11819
Points
12
There is a very good chance that the pendulum regulator wheel and rocker assembly is out of adjustment or has a bent tooth or finger that is jamming the movement.
The adjustment of this is extremely sensitive and so a slight misalignment will at some point show up when the causes of the misalignment rotate to align once again, which is why it is a periodic fault.
Despite it being a very sensitive area and in need of a light hand to remedy, for anyone experienced in working on this kind of movement, it would be a simple and speedy repair.
Unless you have experience of working with such movements, I would recommend leaving it alone and seeking help from a professional, because of the risk of making it worse rather than better, so making it more difficult to repair in the long run.
I have a 1840 Mauthe wall clock that had that exact fault, and once it was properly aligned, it has kept excellent time for the last seven years so be gentle with it.
5 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 23, 2009
SOURCE: I inherited a grandfather clock which runs slow
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
Anonymous
  • 24 Answers
  • Posted on Sep 19, 2009
SOURCE: Watch looses time. Breitling 1884
It sounds like your either not moving enough to wind it (try winding manually) or it needs a service (gear oil gone sticky) to free it up.
Testimonial: "Thanks for the information."
Anonymous
  • 714 Answers
  • Posted on Jan 21, 2010
SOURCE: The pendulum stopped swinging...the clock and
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
Anonymous
  • 714 Answers
  • Posted on Feb 08, 2010
SOURCE: pendulum in beat but stops running after a few
CLOCK OILING TIPS * NOTE: Many Master Clock Smiths and Hobbyists used many different oils and as many different techniques.
* It is only good sense to use only the best in quality when selecting clock oils and grease. A number of fine oils are made especially for clocks. The oil used should stay in place and not evaporate easily and have no tendency to gum or get sticky as it ages. Most clock oils meet these standards. [CAUTION: Never consider using non-clock lubricants, as they tend to not really work well in clocks. Some are too light and cause unnecessary bushings wear, while others are too thick or can evaporate, over time will gum up and stop the clock prematurely.]
Oiling Procedures
-Main-springs are oiled after cleaning and before they are recoiled.
-Teeth and pinions are never oiled.
-Normally, the dial train of gears, hour wheel, minute wheel and minute wheel post are not oiled. However, oil is used between the center shaft and cannon pinion where slip friction is present in setting the hands.
-All points of friction such as train wheel pivots to bushings are oiled. Verge faces are oiled directly.
-Oil is always used sparingly and should never run all over the plates.
Hope this tip helps.
R/
DAvid
http://antiqueclock.clockstop.com/oil.htm
Anonymous
  • 2501 Answers
  • Posted on Mar 13, 2011
SOURCE: I have an Elgin Westminister Quartz Chime clock.
I have a clock with a pendulum and it has two batteries, one for the clock and one for the pendulum.
Perhaps your is the same?
1helpful
Infinity group Pendulum Wall Clock not longer keeps time at all
Check that the hands are tight and also that they are not touching. and jamming. Remove the battery and replace it. Some have a lever to give it a jolt to get moving.
https://www.google.com/search?q=Infinity+group+Pendulum+Wall+Clock
Mar 12, 2023 • The Watches
I have a wall clock, with metal 'scroll work' the clock runs but the pendulum doesn't swing. How to repair the pendulum mechanism?
If your wall clock is running but the pendulum is not swinging, it may be due to a few potential issues with the pendulum mechanism. Here are some steps you can take to repair the pendulum mechanism:
  1. Check the suspension spring: The suspension spring is a thin strip of metal that hangs down from the top of the clock and holds the pendulum in place. Check to see if the suspension spring is properly attached to the clock and if it is straight. If it is bent or damaged, it may need to be replaced.
  2. Check the pendulum leader: The pendulum leader is the part of the clock that connects the pendulum to the clock's movement. Make sure that the pendulum leader is properly attached to the clock and that it is not bent or damaged.
  3. Check the escapement: The escapement is the part of the clock that controls the swing of the pendulum. Make sure that the escapement is properly lubricated and that it is not damaged or jammed. If it is damaged or worn, it may need to be replaced.
  4. Check the beat setting: The beat setting is the adjustment that ensures that the pendulum swings evenly. Make sure that the beat setting is properly adjusted by moving the pendulum to the left or right until it swings evenly.
  5. Check the weights: If your clock has weights, make sure that they are properly attached and that they are not obstructed or damaged.
If you've tried these steps and the pendulum still isn't swinging, it may be best to contact a professional clock repair technician for further assistance. They will have the expertise and tools needed to properly diagnose and repair any issues with your clock's pendulum mechanism.
Feb 18, 2023 • The Watches
1helpful
Is it possible to have a pendulum that is too heavy? The grand father clock is battery operated and the part that swings the pendulum will move back n forth when the pendulum is not on it. If the weight...
It is a handsome longcase clock and rather elaborate - it would be disappointing to discover the weights and pendulum are merely decorative.
I have only encountered one similar clock and it had one battery to keep the pendulum swinging and another to power the clock. The battery had to be fairly fresh or the pendulum stopped swinging. The clock also had to be level or the pendulum stopped.
If you took the picture when the pendulum was stationary, the clock appears not to be standing vertically. It is important they stand vertically in both planes to the nth degree.
There is also a fable about a clock never being happy standing next to or hanging on an exterior wall, sometimes not such a fable...
I don't think the pendulum is the problem. I suggest you should level the clock (considering the shape of the case a plumbline would be best), fit a new battery and give the pendulum a swing - if it doesn't keep swinging, there is probably a fault with the motor.
Oct 24, 2020 • The Watches
2answers
This clock has been in my family for manyyears and it has recently stopped working. The pendulum no longer swings continuously and i dont hear a ticking when i do swing it. My grandpa said something about...
It sounds like the drive spring might be worn. A Good clock and watch specialist will be able to overhaul and service the clock for you. It might cost you a bit more money but if it is a family clock it could be worth it.
Dec 13, 2019 • The Watches
How to fix the pendulum on an elgin quartz anniversary clock
I am unsure wha you mean by "fix the pendulum". If you mean it stopped swinging, there are two reasons: first check the battery and contacts. Remember, even a new battery can be bad, which is why new things come with warranties. The other thing is quartz movements usually don't last too long. If the pendulum is not swinging, and is correctly attached to the movement and the battery is good, then the movement has gone bad and you need a new one. Most all clock shops keep quartz movements on hand. If you are a do-it-yourself type, you can get them off the Internet. Be sure to remove the old one first and check how thick the dial is, that's how they sell them by dial thickness.
5helpful
Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Jan 01, 2011 • Watches
2helpful
I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Feb 02, 2010 • Watches
4helpful
Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
Jan 28, 2010 • Watches
2helpful
What ports wind what?
On mine, the center one (@the 6 position) is the one that keeps the pendulum swinging. It is the one that lengthens the most during the week and if I forget to wind it, that pendulum is all the way down when the clock stops.
May 02, 2009 • Watches
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
