Blank raster with flyback lines on a Philips 21PT135A TV. Chassis type Anubis A AC. The sound is OK.
Gearoid
SOURCE: Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
SOURCE: POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
SOURCE: mode-service of tv philips type:32pw9576/19e
Actually, the code is 0,6,2,5,9,6,MENU on the remote.
SOURCE: Philips model HD2528-C122 value for capacitor C506?
I could still make out 68 over 2kv on the burnt capacitor. Replaced with a 680 pf 2kv that I bought at a local TV repair shop. works great.
SOURCE: On switching Philips Tv type:21PT 240B/94R no sound,picture
I have Philips CTV 21 PT 240B/94R. and this time a problem are when set on chenel are not stop to change only forward and bottom right side Display Scan+
