Home Logo
L
Lolly Mcf Posted on Jul 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have to keep replacing the flapper on my duravit toilet to stop it from constantly refilling due to leaking. Why is this happening? I replaced the last one 4 months ago. How can i prevent this?
  • Lolly Mcf
    Lolly Mcf Jul 25, 2019
    I have tweaked and adjusted everything. There appears to be no obvious issue with the rubber flapper. Yet still it leaks. I also think this is a serious design flaw with Duravit. There’s no way a flapper can wear out in less than 4 months. Duravit needs to address this problem.
  • fasttitlelenders
    fasttitlelenders Aug 13, 2019
    Hi, I found the best article on the internet which may help you to remodel or redesign your house :)https://www.brettkingbuilder.com/service...
J Rosado
Level 3:
  • Master 1,202 Answers
  • Posted on Aug 13, 2019
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
499810
Points
3432
This Fluidmaster worked the first time. https://www.amazon.com/Fluidmaster-555CRP8-Universal-PerforMAX-Minute/dp/B00002N6MI/ref=mp_s_a_1_9?keywords=fluidmaster+flapper&qid=1565727666&s=gateway&sprefix=fluidmaster&sr=8-9
Bill
Level 1:
New Friend:
  • Contributor 39 Answers
  • Posted on Aug 11, 2019
Bill
Contributor
Level 1:
New Friend:
Answers
39
Questions
0
Helped
15881
Points
67
To seal the flapper you need its mating surface clean and smooth, and the flapper has to be smooth and clean at the mating surface and meeting surfaces have to be on the same plane..if all is clean and surfaces meet perfectly..check for alternate seepage areas.
Marvin
Level 3:
Top Expert:
  • Master 85,242 Answers
  • Posted on Jul 24, 2019
Marvin
Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29021762
Points
266281
Are you sure the flapper is dropping back down? Theflush handle may be sticking and holding the flapper valve up.
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Dec 04, 2008
SOURCE: my toto toilet keeps running
if its a metal arm connecting the ballcock shut off valve to the float flush it and bend the metal so the float is lower. if u can adjust the ball **** lower then do so. the shut off is not shutting off cause the float isnt going high enough. and the excess is going down the overflow.
Anonymous
  • Posted on Jan 10, 2009
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Anonymous
  • 512 Answers
  • Posted on Aug 19, 2009
SOURCE: Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Anonymous
  • 396 Answers
  • Posted on Oct 16, 2009
SOURCE: Toto flapper seems ok but toilet keeps slow trickle into the bowl
The water inlet valve should close completely and stop water from coming into the tank before the water level reaches the "small tube." (This is the overflow tube.)
There may be an o-ring or rubber gasket inside the valve that can be replaced. If not, you would have to replace the water inlet valve.
Anonymous
  • Posted on Nov 03, 2009
SOURCE: my duravit toilet keeps running
I too have had this problem. No matter how i change the settings ..sooner or later the toilet starts to flow continually getting worse and worse. I have had plummers and friends etc see if they can make it stop and it is no better. I am very disapointed with it and will never ever buy Duravit again. I tried contacting them for help and got nowhere. Bad design. Waste of money.. I should have stuck with the old ball-**** system at B&Q.
Our toilet systern is constantly running it won't shut down
here are a few things you can check for
  1. Check refill tube first: If refill tube is inserted too far into the overflow pipe, pull it out and reattach to outside of overflow pipe. This should keep the tube from entering the overflow pipe and often stop an internal leak from the tank to bowl and prevent "ghost flushing".
  2. Inspect flapper for visible damage/debris: Wipe flapper and surface area of flush valve clean. Replace flapper if this does not resolve toilet running.
  3. Replace entire flush valve if steps a and b do not resolve issue.
Nov 30, 2017 • Home
The water in the tank continues to leak out and the tank has to continue to refill. I have replaced the flapper, I have taken the tank off the toilet and check gasket alignment. The tank does not leak...
There are only a coulple of places that the toilet could leak or, overflow and give you this problem. When you replaced the flapper valve, did it have an extra piece of rugger on it? Universal flappers have a round piece on them that are designed to fit over the overflow tube. If you flapper had this piece and you don't have need for it, you need to cut that out, if the flapper "hooks" to the overflow assembly. Leaving that piec on can contort the shape of the flapper and make it so it won't seal. If you are noticing constant movement(slight swirl) in the bowl, make sure the back tank is not constantly overflowing into overflow tube. If this is the case, your water level is too high. You will either need to adjust the water level and/or replace the fill valve. If you can hear the toilet running or leaking, push down on the flapper, if it stops, you have a problem with the flapper and/or the chain adjustment. When you install the flapper, you have ton make sure the chain is long enough to let the flapper fall and seal but, not so long that it can tangle or get between the the flapper and it's seal below it.
Replaced the seals because it was running. Water is still leaking from the tank somewhere so it keeps refilling....it's constantly leaking and refilling. how can I repair this.
You say you have replaced seals. I assume that you are refering to the flaper valve that controls dumping water from tank to bowl to flush. To make sure you have a good seal put a dozen or so drops of food coloring directly into tank when it's full and observe for a hour or so to see if water in bowl is discoloring. If it is then you are still leaking there. You can shut off water supply off or flush toilet and manually hold flush valve closed. Check to see if there are any rough spots on flapper seal that could stop flapper from sealing good. If you find rough spot then make sure the surface is dry and sand lightly with medium grit sandpaper.120 grit or finer.
One other thing to check is if your toilet has the plastic or rubber tube that goes from the flush valve into the overflow. Make sure that this tube does not set below water level in tank when it is full as this can create a suction or syphon,
Hope this helps you. Thanks
1helpful
My toilet is a duravit 1930 series model with Euro style push flusher rather than handle. Internal flushing mechanism is not traditional float ball. toilet water constantly leaks from tank into bowl...
A fairly easy ( but messy ) fix - get a replacement tank to bowl gasket and bolt kit, shut off water supply, drain tank, remove bolts ( you might have to cut, depending on your water source and minerals in your water). Remove old gasket and clean surface with 00 grade steel wool. Replace gasket, install new bolts, remount tank.
Good luck!!
OUr 5 yr old duravit toilet is constantly running. Seems that tank water is seeping into bowl causing the mechanism to demand more water. Onl way to stop is to turn of water valve until we need. Before I...
if you can see the water running in the bowl it's a good chance that the flappers warn http://www.aplumbers.com/residential/toilet
1. tank the tank lid off.2. flush the rubber thing that comes up and allows the water to go to the bowl is the flapper 3. remove 4. replace that should fix it.
problem 2
1. tank tank lid off.2. if the waters flowing over the long tube in the center and down then the water level is too high3. adjust the level either it will have a ball **** or a float in either case   a ball **** adjusts by a screw on the fill valve. the float has a either a metal rod w/ a pinch clamp or a plastic long screw type thing.4. adjust water level .5. barely lift handle to allow a little water out til fill valve kicks on then release handle til valve stops .6. just keep re adjusting til you get the water level right there should be a molded in line for the level on the back of the tank.
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 • Home
Same problem. water wont shut off.
You need a new fill valve,Get Fluidmaster style.That is if you have the old ball type.
We find toilet flappers the main reason there is septic backups(leaking flappers)
Good luck.
1helpful
2answers
My duravit toilet keeps running
Top Duravit Home Experts
Mike Cairns
Mike Cairns
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Duravit Home Expert? Answer questions, earn points and help others
