I would check the lint traps and exhaust line to make sure you don't have a restriction in air flow. the reduced air flow could cause the machine to over heat and will not allow it to run till cools down. I think I might also try different dryer setting on the timer just to make sure it is not the timer but sounds like something is getting to hot.
http://www.appliance-repair-it.com/Frigidaire-dryer.html
https://www.youtube.com/watch?v=S9KaJeV_bMQ
https://www.youtube.com/watch?v=dg-vqyRgMPo
https://www.youtube.com/watch?v=QQiZ8OFJINM
https://homeguides.sfgate.com/troubleshoot-frigidaire-electric-clothes-dryer-80372.html
https://www.youtube.com/watch?v=Qg1W9RrxXLY
manual below
https://www.searspartsdirect.com/manual/95gwascbq1-001428/frigidaire-ffre4120sw-dryer
https://manualzz.com/manual/en/Frigidaire/FFRE4120SW/User%2Bmanual
Testimonial: "I tried a different setting (normal to heavy) and the timer didn't run. I clean both the lint traps and exhaust line. Also I disconnected the exhaust line but still the same result, no heat (2nd load)."
SOURCE: Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
SOURCE: Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
SOURCE: dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
SOURCE: Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
