SOURCE: Printed Tape Cuts Off Letters
I was having the ame issue. Found the solution on the user manual (posted online). Press Function, scroll to "Margin", press "Function", use arrows to select "#" or "##", then press Function again. Now it should print with a margin, thus not cutting off your letters. Mine was set to "-", which is basically no margin.
SOURCE: DYMO Labelwriter 400 prints very slowly and incomplete
put in new batteries. The ink is operated by heat, hence you will need to put in new batteries and this should solve your problemn
SOURCE: bottom of letters in document not printing.
it is problem your printer page setup please set defalt or re install printer driver
thanks
xptareq
SOURCE: Swintec 7000 Typing Problem
Try Code comma, peroid or slash one of them will get you out of the overstrike ribbon mode.
DickyO
SOURCE: Normal color print ,black print cuts off top/bottom of letters
Suggest using the printer software utility to clean the print heads, then print a test page.
Hi Nelson Cleveland, I want to help you with your question, but I need more information from you. Call 1 8O5*465*751O Toll 24x7 NETFLIX NUMBER
