Question about Sewing Machines
Juki mo 2316 nEEDLE THREAD KEEPS BREAKING
JUKI MO 2316nEEDLE THREAD KEEPS BREAKING.
WE HAVE RETHREADED EVERYTHING.
WE HAVE CHANGED THE NEEDLE.
DON'T KNOW WHAT ELSE TO DO.
  • 1 more comment
  • Anonymous Sep 09, 2009
    Yes to both, we just suddenly have this problem. I was working one minute and not the next. I have a small home based business, use the best quality thread and needles. We cleaned out under the plate and between the tension disks etc. Still breaks.
  • Obertelli
    Obertelli May 11, 2010
    Have you correctly adjusted the tension on the needle thread? Are you using good quality thread?
  • Anonymous Mar 17, 2014
    I think I have the needle threads wrong from the tension spools to the needles
I took my machine in to a place that fixes machines.
Thanks anyway!
Posted on Sep 10, 2009
6ya staff
SOURCE:
Juki MO2300 Manual book
Search for:
Make Model manual
Apr 17, 2018 | Juki Sewing Machines
Juki Serger - MO-50e thread will not move out of the machine and continues to tangle under the needles. Please help! The machine worked beautifully for a few hours and now it is a really expensive p
I have had this happen, check your tension on that thread and check the thread thickness. Tofix mine I recall changing both,and I think it was the thread thickness in relation to the tension
Oct 29, 2014 | Juki America, Inc Juki MO-50E 3/4 Thread...
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
Shredding thread
have you checked to see if the needle is inserted into the needle
holder correctly
have you checked to see if it's the correct size needle for the machine& for the fabric
check for burrs in the needle plate area & on the bobbin case
if these suggestions don't help then it's possible that the machine
needs to be checked at a sewing machine shop to see if the
machine could be slightly out of time.
Aug 20, 2012 | Sewing Machines
Right needle will not stay threaded and sew
try using a longer thread tail of 4 to 6 inches, that what I do & my
needles never come unthreaded
Aug 12, 2012 | Juki MO-644D Mechanical Sewing Machine
My right needle thread keeps pulling out on my Juki 655 - how do I fix this?
make sure the top tension is not to tight
keep longer thread tails for 4 to 7 inches
keep the thread pulled behind the needle before you start sewing
see if that helps solve the problem
Jun 05, 2012 | Juki MO-654DE Mechanical Sewing Machine
The right hand needle on my Juki MO-634DE keeps breaking. I ensure that it is inserted correctly - any ideas?
I would suggest rethreading that one section, then check the tension to make sure it's correct for the
fabric,
also check to see what the needle it hitting to break it, if it's hitting the loopers or the needle plate area
then it's possible it could be out of time, then it would have to be serviced
Sep 26, 2011 | Juki MO-644D Mechanical Sewing Machine
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
How do I thread the Juki MO-644D?
Email me at sewingnz@gmail.com should be able to help.
Jan 19, 2010 | Juki MO-644D Mechanical Sewing Machine
My thread is breaking when I'm sewing on my Juki DDL 555
MAKE SURE YOU HAVE THE RIGHT NEEDLE FOR THE THREAD YOU ARE USING, AND THAT THE SAME THREAD IS ALSO IN THE BOBBIN. CHECK UPPER TENSION, BY PULLING SLIGHTLY, IF IT'S TIGHT, LOOSEN THE UPPER TENSION.YOUR THREAD MAY BE THE WRONG SIZE OR TYPE FOR THE SPEED YOUR SEWING., and the needle your are using( sorry about the caps lock)
Oct 18, 2008 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
734 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
