SOURCE: need manual for 48
Hi..my name is Keith...and you can go to an online lawn mower parts site and they will have a parts diagram of the deck and it will show how the belt is installed....one of the sites is.. www.outdoordistributors.com ..i hope this helps
SOURCE: I need a digram of replaceing a drive belt on
You can download the owners mqnuqal here:
http://dl.owneriq.net/2/2141e15a-36a6-9594-0166-6f10fba50f44.pdf
It has full instructions as well as diagrams
SOURCE: I have a Husqvarna Pro Rider 15 ride on mower,cuutting deck broke
You may find this helpful. A complete manual you can download and use for this and other repairs.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqom88hoen2003_1140142-26rideen.pdf
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
