Dryers Logo
Robin Pouliot Posted on Jul 25, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung gas dryer when turned on panel lights up but nothing happens, the icon that looks like an hour Glass comes on and when I try pushing on the time or a different cycle Which I'm able to do but still won't turn on
Robert Oliver
Level 2:
Sergeant:
  • Expert 323 Answers
  • Posted on Aug 06, 2019
Robert Oliver
Expert
Level 2:
Sergeant:
Answers
323
Questions
Helped
84954
Points
959
You'll need to quote the actual model number of the dryer, so that any specific information can be found.
Samsung make a bunch of different gas dryers.
1 Related Answer
Anonymous
  • 1998 Answers
  • Posted on Jul 04, 2011
SOURCE: Have a Samsung gas dryer, power comes on and panel
What is the model number for the samsung dryer? Usually when this happens there are small thermistors that act as safety devices in the dryer that will prevent the unit from running. For example there is a hi and low limit thermistor that if either will faulty the unit would not run at all the lights would come on but the unit would not run to prevent the unit from getting to hot. Message me back your model number and I will find your schematic showing the thermistors in your unit. You would have to check these thermistors with a multimeter and perform continutity tests on them to assure that they are functioning properly. I await your reply Thanks Rick
Samsung dryer where to press cancel on hour glass pops up
An hour glass on the display, it is normal. The hour glass is there to let you know that there is a cycle in progress.
2helpful
Have a Samsung gas dryer, power comes on and panel lights up. push start button and lights come on but nothing happens, dryer won't start???
Lights come on and you can choose your cycle but when you push start i hear a clicking at the top but it wont start
YOU HAVE A BROKE BELT,,, WHEN THE BELT BREAKS IT SHUTS OFF A MICRO SWITCH,, THE TIMER WILL WORK BUT NOTHING HAPPENS
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
4helpful
2answers
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Nov 02, 2008 • Dryers
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Top Samsung Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Bill Eager
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
