For removing Windows login Password safely, I highly recommend software program Windows Password Reset 9.0. Not only support XP/Vista/2000/NT, but also compatible with windows 7, it works perfectly to reset Windows login Passwords. I burned it to a USB flash drive. Booting up and clearing my password within just 4 minutes. You could Search Windows Password Reset 9.0 or download it from: http://www.reset-windows-password.com/how-to-reset-windows-password.html
I believe probably the easiest and safest way for you is remove your Windows OS Passwords with Windows Password Recovery tools. I found a good one at http://www.reset-windows-password.com last week, and then I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose. It's worth an attempt.
If you forgot windows password, you could get into safe mode (F8 when booting up) to remove windows password while you lost user account password, but if you forgot admin passwords, there is no way to change it, you need to use software to recover admin password. A week ago, I forgot my Windows admin password. In the end, I successfully recover my Windows password by using Windows Password Seeker. It's worth an attempt.
http://www.passwordseeker.com
Unlock bios
password compaq nc 6320
Related searches: Good Luck / Please dont for get to Vote.Thank you.
its a compaq presario 1500
i have compaq v2000 series laptop
my lap hdd password problem how to slove
turn the system compleatly off {hold for 10 seconds } then while turning it back on hold the volume up button this witt take you to system recovery or something like that then restart ur device { everthing will be deleated }
how to toshiba labtop hdd password unlocked
how to toshiba hdd unlocked
