Batteries went dead while the zoom was out, couldn't get the zoom lens back in. Changed batteries and the zoom now reads error zoom, and won't go back in.
i read the manual, and they recommend bringing it to a service center, after turning it on and off. Sometimes sand gets stuck in the lens, or sometimes the internal button cell battery goes dead which would disable the zoom. If you feel confident in your component abilities, crack it open and replace that battery.
Try to put it on super macro and see if this will reset the zoom function. Also try to switch between the settings that allow the digital zoom, as compaired to those settings that only allow optical zoom. If these do not work, you may have a lens that has been dropped, or is stuck, and may need to be serviced. I have the S700, and have never seen this error before> good luck.
I have had the same problem with my camera. It mostly occurs when my battery is going dead. It will go in and out while trying to turn the camera on and off. It will get stuck open and stuck closed and sometimes half way.
I put new batteries in, and it works like a charm. I can now tell my battery is going dead when it starts to behave that way.
This should work for the A520. With NEW or freshly recharged batteries, remove the camera's memory card, then turn on the camera. You'll probably see an E30 error. Next turn off the camera. Next insert the memory card, and turn on the camera.
If the above doesn't work, the following blog outlines some other repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
It sound like a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem.
In any case it could not make it worse
