SOURCE: canon IR C3220 cannot print multiple pages..ONLY able to print one page
The answer depends upon the printer controller that your 3220 has. There are at least 3 controllers & probably twice as many versions for the assorted printer controllers. The key is do you have a Fiery (Little white box hanging on the back) or does the network connect directly into the NIC on the upper left corner of the copier. Drivers with -C1 or -C2 connote a Fiery printer driver. I would advise using the PS drivers if this is the case as the Fiery is much better at PS than PCL. Another way to tell if Fiery is on copier is scroll to right on LCD panel & see if there is a "Printer" screen. If so you can go in to "functions" "Print Pages" & print a "Configuration" page. this will show you the network ip#. Put the # in your web browser (no http:// etc needed) & you can download the correct drivers for Mac / PC right from the device. If no Fiery is on the device stick with PCL5C drivers as they are usually the best for Canon PDL board print controllers.
SOURCE: e000 in canon ir 1600
i have one canon ir 400 that mc showing eror e004 how to slove this problem
SOURCE: Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
SOURCE: canon iR 2520 toner install problem.
u can go in service mode by pressing additional function + 2+8 then go in clear by pressing scrolling, then go in engine. after press ok in tnrinst. machine will process for 2 minutes. for toner installation.
SOURCE: today I start my printer
oday I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution for disable or reset the same.
How to clear E000, E001, E002 and E003.
1-Enter service mode by pressing additional functions than 2 than 8 and then Additional Functions.
#SSSW will be displayed.
2-Use the right arrow and scroll to #CLEAR then press OK.
3-Use the right arrow and scroll to ENGINE then press OK.
ERRCLR will be displayed then press OK.
4-Then power cycle the machine.
Service Mode : ADDITIONAL FUNCTIONS>2 KEY>8 KEY> ADDITIONAL FUNCTIONS>#CLEAR>ENGINE>ERRCLR.
Note: This mode should be used to clear all Fixing related Error Codes.
If this does not resolve the error code. / u need to call for service or if u are a tech--pull out the fix unit to inspect
Hi bruk mekuria, I want to help you with your question, but I need more information from you. Please Call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7
