The washer makes a loud squeaking sound when it is operated on the “Cottons” side of the wash select dial. The sound gradually becomes less loud but it is still present as the machine runs through its cycles. The squeaking happens at each time that the machine must agitate (washing or rinsing) but it does not squeak when the motor is spinning and expelling water from the clothes (unless at this point the squeak is so high-pitched I can’t hear it). There is no squeaking sound when the machine is set on the “Easy Care” side of the dial. I am sure one side (Cottons) agitates more vigorously than the other side hence the presence or absence of the noise. The washer runs fine in all other respects (spins so the clothes are almost dry for the dryer, drains well, leveled correctly, fills properly) but I am sure the squeaking sound is wearing the machine faster than it should. I appreciate any assistance or suggestions.
Regards, Rick
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
For more on do-it-yourself appliance repair help visit http://www.appliance-repair-it.com/index.html
Testimonial: "shawnryan111, thank you for a great suggestion. That did the trick and the machine runs much more quietly. Thank you for the assistance. Regards, Les"
any help about washing machine so visit my site
it will very helpfulhttps://helpdeskminority.com/category/wa...
