if its new,call the manufacturer,they will send someone to fix it for free,or,replace the fuses inside with THE SAME EXACT TYPES,not different cheaper ones,the exact ones,some blow fast some blow slowly.
I have not repaired this model. My first thought are bad capacitors in the power supply board. If you do have the exact board to replace. I would certainly do so. Numbers check and you say they are the exact same, should be an easy fix. If this board came out of another TV of the same model, you must remember, it will have the same longevity as the board that does not work. I would compare the boards, and look for bad capacitors on the board that does not work of course. You may check the capacitors with an ESR meter (about 50 to 75 bucks). The purchase and price of one of these will pay for itself. You can fix other electronics. Thanks for asking Alan. I'll be here if you have more questions.
What exactly is the issue? I need a bit more information here, but am sure I can help you. What is the model number of the TV, and what exactly are you experiencing that you need to "fix"?
something on the mainboard went bad and shut the tv down and whatever part it is will be on the new mainboard.by replacing the board you are replacing the problem
yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
