Question about Becker Indianapolis Pro 7950 CD Player
Becker/BMW Indianapolis randomly turns itself off and sometimes produces cracking noises on the outputs while playing cd/mp3
I bought a second hand BMW and it came pre-installed with a BMW Indianapolis radio navigation unit. This unit is actually a Becker Indianapolis 7969. The 7969 is an Indianapolis 7920 but with slightly different software for BMW and orange illumination. It's also almost identical to the Becker Indianapolis Pro 7950 except it lacks bluetooth support. But those differences are not related to my problem.
This unit experiences two problems that may or may not be related:
1. After a while the unit turns itself off. Sometimes this happens just minutes after turning on, other times it takes hours. I have it both when playing cd/mp3 or when listening to radio. A press on the ON-button and the unit continues where it left. I took the unit out of my car to test it in controlled environment (stabilized high end 13.8V/10A power supply) but it's showing the same effect. I don't think it's heat related because once the unit turns off you can immediatly power it up again and sometimes it will play again for hours.
2. When playing cd or mp3-cd the unit sometimes
produces "ticking" and "cracking" noises. This happens on the amplified outputs as well as on the line-outs. Sometimes it's just a few cracks every now and then, other moments it's like you're listening to a bad tuned in radio station - except that it's the cd/mp3 playing. When I switch to radio, the cracking is gone. It never happens during radio playback. When I switch back to cd/mp3 the cracking continues. Sometimes it goes away after a while. Power cycling does not seem to have any effect, nor does heat. It happens both when the unit is cold or hot. It's independant of the volume (it's definitely not an overdriven signal). The same problem occurs in my controlled environment with the unit connected to a receiver, so it's not a groundloop or alternator whine related issue.
BMW is of no help. I contacted Becker Europe, but either I completely missed their technical support department or they didn't feel like helping me with a unit that's long out of warranty. I got a reply they can only help me with operation and installation questions. Great... If someone can give me a link / email address to reach Becker's REAL technical support, I'd be grateful.
I don't mind opening the unit, nor am I afraid of some fine soldering. But I need to know where to look - what may cause issues like this.
Thanks for any help you can provide!
  • mahi2003 Dec 10, 2007
    Just some extra information for the random power off issue:
    Using my power supply I can keep an eye on the current the unit draws. It's around 0.75A for radio playback up to 1.0A for cd/mp3 playback (using line-out).
    When the unit turns itself off, the current draw remains 0.75A for about 4 seconds after the music stopped and the illumination went dark. Then it drops to 0.5A for a second, followed by 0.35A for 3 seconds. Then it drops to 0.01A and I can hear a soft plop in the speakers indicating the amplifier/pre-amplifier is shut down.
    Why may this be important? When I press the ON-button (which turns off the unit when it's on) I see exactly the same behaviour. In other words, the random power off issue is behaving exactly as if someone would have pressed the ON-button. So it's a "graceful" shutdown, not a sudden power loss or crash.
    There's nothing wrong with the ON-button, though. It's not loose or making false contact.
  • mahi2003 Dec 11, 2007
    Ok, the power off issue is fixed. It was not that random after all. Must have been a wrong perception from my side. Once I timed it with a chrono it became apparant this was intended behaviour.
    The cause is simple. The permanent + is attached to the battery (or my power supply), but the switched + was left unconnected. Once that's hooked up, the unit doesn't power down until you disconnect the switched +. If the switched + is off, and you turn the unit on, it plays for a preset time and then, shuts down to save the batteries.
    My bad... I should have looked into this a bit more carefully.
    The cracking noise issue is still here though. Any help with that would be really appreciated.
    Scholar:
    New Friend:
  • 88 Answers
The fact that you pulled it out of the car and tested it using a known good power source says more about your troubleshooting skills than most. Now you're ready to do the inevitable... tear it open. Open it up being mindful of internal connectors and possible ground leads coming from amp boards to the chasis. While there is likely no prints available for this unit for schmucks like us there are some very key things to look for.
1. Burnt components. Easiest to spot but hardest to identify. Hopefully there's another component nearby this one to help identify it. There are many online sources to purchase new components.
2. Deceased and bulging capacitors. Many electrolytic capacitors will swell up when they have given up on life. For safety reasons (preventing them from being a IED) the manufacturers have put little cross hatch cuts in the top to relieve the swelling when the electrolyte boils. This makes it easy to spot and caps are super cheap and easy to find. I do recommend getting one of exact value in the uH rating but suggest maybe bumping up the voltage (i.e. going from a 12vdc to perhaps a 16vdc). This will make them last longer in general.
3. Loose connectors. Give a little tug on each connection to see how much they're clinging to life.
Posted on Mar 01, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Indianapolis pro soft instaltion problem
"If a malfunction of the unit should occur,
such that it becomes inoperable or defective
in some other way, a restart of the
internal unit software (reset) can be triggered
with the following button combination:
To trigger a reset, simultaneously press '1'
multifunction button , '3'multifunction
button and 'tel 'the button.
After a reset of the unit software, the
Navigation CD must be re-inserted."
Posted on Feb 19, 2009
xxxxxx xxx
  • 5013 Answers
SOURCE: Radio code becker indianapolis
Try code 34211
Posted on Sep 07, 2009
Testimonial: "Thank you, now i can use my radio again.."
xxxxxx xxx
  • 5013 Answers
SOURCE: security code becker indianapolis
Try code 42332
Posted on Sep 16, 2009
Testimonial: "Thank you very much from Holland!!! Eureka from Jo"
xxxxxx xxx
  • 5013 Answers
SOURCE: I lost my becker indianapolis
your code is 31232
Posted on Jan 28, 2011
saem242
I hope that someone can help me please. I changed the battery of my
car and lost my key for my Becker Indianapolis Pro
ser no 7950cj065002682
Thank you guys for your help!
Posted on Apr 14, 2011
I lost my becker indianapolis pro code, typ be 7953, serial no 65004094
I lost my becker indianapolis pro code, typ be 7953, serial no 65010437
Nov 17, 2011 | Becker Indianapolis Pro 7950 CD Player
NEED CODE FOR BMW BECKER RADIO
If your radio require a 4 digit code then try 5373
Oct 03, 2009 | Becker Indianapolis Pro 7950 CD Player
I lost the radio code from my BMW Indianapolis!
Go to your local BMW dealership with your vehicle ID # and the Radio serial #. The can look it up or call BMW direct to get it. Other Auto manufacturer's charge 20-25 to do this, I'm not sure what BMW will charge. Hope this helps
Sep 27, 2009 | Becker Indianapolis Pro 7950 CD Player
Becker Indianapolis Pro 7950 CD Player Logo
2,762 people viewed this question
Top Becker Car Audio & Video Experts
Colin Stickland
Colin Stickland
Gil Shultz
Andrew Taylor
Andrew Taylor
Are you a Becker Car Audio and Video Expert? Answer questions, earn points and help others
