The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!! If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I have the same problem! washer stopped during wash cycle & will not work any more..still has wash water in it & prior to it completely stopped working, it made a loud grinding sound during the spin cycle & sometimes just during the regular wash cycle.
sav4710aww will only fill to mini wash then stops
