SOURCE: Bosch 4000 table saw won't work
OK sounds like you are handy. You have electric to the brush tubes? (first unplug saw to test) If yes then I would remove the brushes to see if they were making contact with the commutator. Does the blade spin freely? If not you might have a bearing problem. I would again use air after removing the brushes and then reinsert making sure they seat on the armature. If still nothing then if you are comfortable I would pull the motor housing. But before pulling go to Bosch Tools website and downloading a breakdown of your saw. Let me know if I can help
SOURCE: Bosch 4000 table saw disassembly
turn the motor housing slightly until you can put a screwdriver between the housing and diaphragm, pull on the one side and push with the driver and it will come apart, I just did one yesterday. To get the armature out of the fan bearing you will need a dead blow hammer to tap on the diaphragm while pulling on the armature. The bearing is held in place with 2 screws, hope this helps.
Testimonial: "Hey thanks! It seems they really don't want you to work on the motor on this particular saw. Thanks again for your help. "
SOURCE: need manual for bosch 4000 table saw
You can get manual at link below.
owners manual.
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00160v-1.pdf
Parts diagram.
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00442v-1.pdf
Good Luck
SOURCE: will the skil 80092 table saw stand accomodate the
Yes it will hold the Bosch 4000 with a little modification.
Testimonial: "Do you know what modifications i would have to make ? It would be of great help to know what i'm getting into before i purchase the stand!! Thanks "
SOURCE: bosch 4000 table saw run
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
