Viking DEDO205 Stainless Steel Electric Double Oven Logo
Posted on Dec 11, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Viking: VEDO205 Blew my inner glass door
I tried to self clean for the first time and it blew my upper inner glass door, The question being how should I go about repairing it. I know the oven is probably around 6 years old is there a chance Viking can replace it and could I repair it mayself if they don;t?
  • 1 more comment
  • Anonymous Apr 10, 2009
    I have the same problem, What did you do to fix it.
    I do not mind fixing this on my own, but having a hard time figuring out the right Part# for the glass.
  • needn Apr 10, 2009
    Same here, I need the Part# and the place where you can order the same.
  • Anonymous Jan 10, 2013
    call an authorized viking part supplier with the model number of your appliance. They will be able to look up item you need.
Anonymous
Level 2:
Scholar:
  • Expert 196 Answers
  • Posted on Jan 26, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
196
Questions
Helped
113280
Points
300
If you can take the door apart then you can fix it. Remove all the retaining screws to access the inner glass.
My Viking electric oven will not self clean, any suggestions.
Ensure the door is closed securely if the Viking oven will not enter the self-clean cycle. If the door is not closed completely, the door lock cannot engage to start the self-cleaning.
https://www.hunker.com/13408313/how-to-troubleshoot-a-viking-oven
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
The oven will not get hot on the self-clean option, but it will get hot when just using the regular oven
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
I did the self clean on the upper oven. When the stopped cleaning it cooled down, but the door will not open. (Unlock)
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
1helpful
The front glass blew out of it! Completely shattered and no one had touched it. Now we need to clean it up. I suppose we need to take off the door and get a new one. OR do we get a new glass plate and...
Hi and welcome to FixYa I am Kelly.
Since you did not include a model number this solution will be from the hip as I can not refer to any manuals to assist you. Most ovens the oven door comes off by tilting the door out to the first stop and then lifting is vertical inline with the position of the hinge at the bottom of the door. Some of them may have retaining screws on the inside of the door to keep the door attached to the hinge area that must be removed FIRST. The hinge itself should stay attached to the oven.
I can probably provide you with a source (Maybe more than one) for the door glass if you respond with a model number,
When you attempt to take the door apart lay it down on 2 rugs so you do not scratch it. Use some blocks of wood UNDER the rugs to prop the door up so as not to damage the handle.
The door glass is replaced by removing the screws from the indide of the door. Sometimes you have to remove the trim pieces in addition to the multiple door panels. Everything is done from the inside of the door. You must take out the inner panel, Then the inner glass, then the spacer, the insulation if any and finally the outer door glass. Reassembly is in reverse order. Outer glass, spacer, insulation if any inner glass, the inner panel and re-install the trim if you had to remove it.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 • Ovens
Dirty streaks between glass front
depends on type of unit,but most separate by opening oven door and removing the screws around the perimeter of the door, be careful reinstalling as to get inner and outer glass re-positioned right along with insulation,this is especially critical because the outer glass can't withstand self-clean temps and will break
Aug 22, 2009 • Ovens
Frigidaire Self Cleaning Electric Oven - Inner glass shattered, need part and instructions for door
It isn't that tough to change the glass assembly. Most of the Frigidaire have 4 screws that hold the front of the door to the inner part- sandwiching the glass in between. It is only sold as a unit- 2 glass pieces, assembled with an aluminum frame. Call All brands Appliance parts at 508-587-7100 and they'll get the part out to you. (Tell them Greasy Wheels sent ya, they'll take good care of you.) The most common reason the glass breaks, is a scratch in the glass. Sometimes it's just a dragged pan, other times it's from cleaning it with a sharp instrument. Don't do that....
Oct 24, 2017 • Ovens
2answers
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Top Viking Ovens Experts
ZJ Limited
ZJ Limited
vince
john h
Are you a Viking Oven Expert? Answer questions, earn points and help others
