Unable to send texts on Nokia N95 have performed complete reboot and wiped everything then did firmware update to most recent have removed sim and battery have deleted and reentered message centre details.... at a loss now what to do any suggestions? can receive messages and send audio meassage but no MMS or SMS.
You should update your phone firmware software by Nokia Software Updater or do a factory reset of your phone.Reset code is *#7370#.This code will reset your phone to original settings
back up your files,then perform a manual format by typing on your phone.*#7780# or *#7370# and type the security code prompted in your screen and wait until rebooting completely done.and try to make a text and send it.enjoy...........
kindly reset like below or pls update ur phone firmware from NOKIA
download update application from www.nokia.com for ur mobile N95 and it
will help u in this software issue
but pls first try to reset the device like this it may resolve it
and RATE ME WELL !
Option 1 Press Call + 3 + * simultaneously during the bootup phase, forces the N95 to do a complete wipe of internal memory.
This will reset the phone back to 100% standard factory configuration.
Option 2
Master reset 1) *#7370#, then enter 12345 (This is the default security code unless the user has changed
it) and then Yes. The phone then wipes all apps and phonebook contacts
on the internal memory.
hi there...try to format your phone...enter this code *#7780# then after that try to check things out if its now working well...hope this will help you
Your mobile phone has a virus so you will need to take the phone to a mobile service center and have them re-flash the phone to correct this issue....or you can try downloading an anti-virus to correct this issue.
I've got an N95 and heard alot about bugs with v21.016 so not updated it myself yet. My advice to you is to back up and try re-installing v21.016 again.
failing that try a reset by entering *#7370# on the main screen...
Make sure you've got everything backed up though, as it will wipe everything from the phone memory.
I think that there is s problem with the phone's firmware. You should update/reflash your phone's firmware with NSU (Nokia Software Updater). Good luck!
