Question about Alcatel OT-C701 Cellular Phone
How to Cancel alarm alcatel 5054
In settings,clock,no alarm options.
    Top Expert:
  • Alcatel Master
  • 30,687 Answers
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: weekend alarm cancel function
hit the cancel button then the wake1 or wake2 button as you need to cancel them.
Posted on Jan 15, 2008
Anonymous
SOURCE: I cant find the alarm clock on N79? I have looked
Go into your phones menu, press applications, then press clock and there, your alarm menu is hiding. Hope this helps.
Posted on Mar 17, 2009
SOURCE: I pressed the self clean option and the oven
F8 code means your door latch assy needs to be replaced. Two options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Posted on Feb 10, 2010
danthomasdou
danthomasdou
SOURCE: Anyone know how to set clock on iCoustic A-101 iPod Dock/Clock Radio?
Ok I have this figured out, if it's the A-101a dock, with the power turned off, double click the MEM/SET button, that will get you there! Choose from format first (24/12 hour time) then click again for hours and minutes. Took me ages, just figured it out!
Posted on Aug 02, 2012
The alarm is set and I do not want it go off anymore and I cannot find a way to clear it
About 5,060,000 results (0.64 seconds) Search Results
    Set or cancel alarms and snooze - Android One Help
    support.google.com > Android One Help > Apps > Clock
    GoogleSet, delete, and label alarms Set new alarm or repeating alarm Open the. ... Open theClock app Clock . Touch menu More > Settings. Under "Alarms," you can ...
    How to Cancel the Android Alarm ' Chron.com
    smallbusiness.chron.com > ... > Start Up Businesses
    You can cancel your alarm after it goes off to stop that occurrence ... ... going off; turning an alarm off has to be done by managing the app's settings. ... Alternatively, you can tap "Snooze" to set the alarm to go off again after the ... Tap "Clock.".
    Setting and using the alarm - Bose
    worldwide.bose.com/...setting...alarm/page.html
    Bose CorporationLearn how to properly set and use Alarm 1 and Alarm 2 by following these ... There are two alarms indicated on the clock display as ALARM (primary) and ...
    How do I set, cancel, and delete an alarm (including settings ...
    support.lenovo.com/us/en/documents/ht101173
    Lenovo
Jan 30, 2016 | Home
How to turn off alarm?
Alarm
Your mobile phone has a built-in alarm clock
with a snooze feature. You can set up to five
separate alarms and choose whether or not
the alarm should repeat.
Setting an Alarm
1. From the main menu, select Alarm.
2. To edit the alarm, press the () key. The
following options display:
• Time: Set the specified time for this
alarm.
• Repeat: Select Once (default)/Every day/
Days or customize as preferred.
• Snooze: The alarm will repeat at regular
intervals.
Jun 15, 2014 | Tracfone Wireless Alcatel A392G
Dictioary i need to turn off
You can go to message settings or the options in message and look for dictionary or T9 and turn T9 off.
If you want the alarm to ring each morning you can go to clock or alarm and set a particular time and set the repetition to everyday or weekly as you desire. You can also cancel the alarm simply by deleting or removing the alarm time that you have set which will be given in the options
Sep 17, 2012 | Samsung Galaxy Note - 16gb - Black...
I cant find an online manual for an audiovox CD alarm clock radio model 1167, and cant figure out how to set the alarm. a link to the actual manual would be great
With the power off, push the alarm 1 button, then push the clock set button. Use the skip & preset buttons to set the hour. Push the clock set button again to change to the minute. Again use the skip & preset buttons to set the minute. Push the clock set button again to set. You will see an alarm clock in the upper left of the screen to show the alarm in now set. To cancel push the alarm button and then the stop/alarm off button.
Mar 09, 2011 | Hardware & Accessories
Where is the alarm clock on the nokia N79 phone
For getting Alarm clock application in Nokia N79,
1) Press Menu key, and select Applications > Clock.
To cancel an alarm, select Options > Remove alarm.
Feb 19, 2011 | Nokia N79 Cellular Phone
Can't disable alarm feature on colock radio
Just press "Cancel" once and then press the "Wake Mode" button until the selector light cycles through the the music or tone modes...and then disappears.
Mar 07, 2009 | GE 7-4837 Clock Radio
Weekend alarm cancel function
Oct 28, 2007 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
Alarm
SLIDE THE SWITCH TO TIME DO NOT PUT ON WAKE 1 OR WAKE 2 THOSE ARE LIKE TWO SEPEATE ALARM TIMES YOU COULD SET PUT ON CANCEL OR JUST TIME.
May 28, 2007 | GE RP4842 Clock Radio
Alcatel OT-C701 Cellular Phone Logo
Top Alcatel Cell Phones Experts
Tony Pez
Level 1 Expert
Dakshinamurthy...
Ron Rak
Ron Rak
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
