Question about Reebok Exercise & Fitness
I have a Reebok GT40s treadmill it suddenly stopped working and is showing E2 error, any explanation appreciated, thanks
    Top Expert:
  • Reebok Master
  • 66,490 Answers
Check with the manufacturer
Posted on Aug 14, 2019
5 Suggested Answers
Anonymous
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
sirrom5691
SOURCE: E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Posted on Oct 14, 2009
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Posted on May 24, 2010
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Posted on Jun 27, 2010
jlam1007
SOURCE: Brand new Sole F85 incline shows e2 and stops
Same thing happens to me. Any solutions?
Posted on Dec 04, 2010
Error message E02 on Reebok ZR8 Threadmill - please help if possible
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 01, 2016 | Exercise & Fitness
My reebok irun treadmill suddenly stops with E3 error code displayed can you help me please.
Try lubricating the belt. My treadmill requires lubricant every now and then. Its not your treadmill but a treadmill is a treadmill. That's what stops the belt from slowing down due to friction. Go to your nearest Gym they may be able to sell you a tube of lubricant. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Oct 23, 2016 | Reebok Exercise & Fitness
Error code E-02 on a reebok z8 treadmill
Hi. Have error code e2 on reebok z8 can you advise what this is.
Thank you.
May 31, 2014 | Reebok Exercise & Fitness
Reebok Treadmill error code 5
Exactly same just happened to my brand new Zr9 (error 5). Reebok said they would replace the motor or complete tredmill or my money back. Undecided as to what to do but thought i was buying a reliable bit of kit ??? They do cover it with 2yr warranty and it is really nice use, will research a bit more before deciding.
Feb 20, 2014 | Reebok Exercise & Fitness
see the video and proceed according. Of course you must lube the rollers bearing front and back.
God bless you
Sep 18, 2013 | Reebok Exercise & Fitness
My Exerpeutic TF1000 treadmill shows a E2 error, motor will not start.
see this steps and fix it.God bless you
This is probably a 1( faulty speed sensor, adjust it , clean it and tigh the plug very well see the diagram attached. 2( test the input voltage motor, if there are the motor need repair 3( test the output voltage board, for input voltage motor, if there are NOT the board is faulty see the block diagram . The error codes will differ between makes and models but could be e1. or e2
Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Oct 01, 2012 | Ironman Exerpeutic TF1000 Walk to Fitness...
I have a reebok Z7 treadmill and it's showing err 2 when I switch it on
this happen can be E1 OR E2 whatever because this change from some manufacture to another. This mean:
1) LUBE the deck belt,very well
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there ARE not, the board is faulty.
see the block. Try to run the sofware calibration after you fix,
God bless you
Jun 28, 2012 | Reebok Exercise & Fitness
Jun 26, 2010 | York Barbell Home Use Fold-Up Treadmill
Exercise & Fitness Logo
158 people viewed this question
Top Reebok Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Christopher DeSantis
Level 1 Expert
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
