Question about Toro Garden
Toro z4200 turns over no spark. New switch,relay,plugs blade switch,alternator and fuses. Ran till alternator shorted out.
    Sergeant:
  • 398 Answers
Replace the ignition coil
Posted on Oct 10, 2019
Anonymous
SOURCE:
Anonymous
SOURCE: Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Posted on Jun 13, 2009
Anonymous
SOURCE: replaced alternator and battery is good but not charging
I found the problem YEAH. It was the fuse that is in the side of the fuse box under the hood, Its where the battery wire from the alternator connects thru a fuse to go to the battery, Its one hundred and something volt fuse. It took care of the problem instantly.... Thank you all for your replies...
Posted on Sep 02, 2009
Anonymous
SOURCE: I need a toro z4200 drive belt diagram as my belt
I have the same problem and juts figer that out and put back on but still not working,
Posted on May 02, 2010
zwordsman
  • 77 Answers
SOURCE: xterra car quit running. had no spark @
Yes, there is fuel pump relay, which is generally located on the passenger side kick panel. But in your case, the fuel pump relay on 2002 model Xterra is indeed located under the dash around the steering wheel, but no you don't need to remove the cover just lay in floor and you can see it, it will slide off a bracket and you can remove and replace it.
Good Luck!
Posted on Jan 15, 2011
Daniel Morton
  • 747 Answers
SOURCE: Toro Z4200 Kohler engine. I was mowing and shut the mower down. When I tried to restart it would not start, not even a single fire. Starter works fine.
check for spark is the wire on the spark plug is the plug good check for fuel flow possible electrical short
Posted on Jul 07, 2012
Timecutter z4200
If you were able to jump start mower then the problem lies with the battery connections or battery itself
Jul 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro Z4200. 60 hours. The starter has always seemed balky but never failed to start. Now, with a completely charged battery, it would not turn over although it sluggishly tried. Seemed as if the starter...
if you touch it , the warranty is void
best talk to the service dealer and get written permission before you touch it
blowing fuses is a dead short after the fuse
could be a problem solenoid ( dead short inside )
Apr 08, 2017 | Garden
3 year old Toro Z4200 time cutter Z, 19 HP Kohler, engine runs great, new battery, new solenoid, with the seat sensor connected or by-passed, STILL WONT start off the key switch. Clicks at the kill relay....
My tractor is doing the exact same thing now. Did you ever get this problem figured out? I figure it to be a grounding problem, a short, or this "kill relay" problem.
Aug 23, 2010 | Sport & Outdoor - Others
Toro Zero Turn adjustment
i have the same problem I wish I knew what was doing it I also changed the shaft and still. Could the blade be upside down?
May 30, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Toro TimeCutter z4200 will not start
First check to see if there is a fuel shutoff under the tank. On some models there is a fuel filter screen inside the tank where the fuel line connects to the tank. If niether of these work, R&R the carb.
Apr 08, 2009 | Toro Lawn Mower With Toro Power Tools
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
66 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
