Move the TM away from the router.
or neuter the TM wifi, inside, pull card, or antenna. inside.
or warp the TM wifi box in aluminum foil (faraday shield magic)
if you shield that wifi modem that kills dead the whole house for wifi.
move the router or TM, or shield or
neuter
the TM wifi card.
To render ineffective or powerless: meaning 2 websters.
wifi is RADIO and as such RADIO cures work.
distance (either or both)
disablement.(TM end)
shields. (TM end)
1,2,3, all work. every one works.
I am licensed by FCC. so ... there go.
If the treadmill produces that much RFI that it interferes with your modem, the ONLY thing you can try is shielding of the modem -
https://www.instructables.com/id/Shield-Your-Wireless-RouterModem-From-RF-Energy
SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
SOURCE: Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
SOURCE: Trying to use SpeedStream 5100 with new DSL Provider
I have Centurytel myself, so maybe I can help:
A link to your Speedstream 5100 router:
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
And the typical setup for the westell 6100 that centurytel uses:
Centurytel will provide you with your username and password.
PPPoE Configuration:
VPI 8
VCI 35
Protocol: PPPoE
Hope this helps.
SOURCE: linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
