Tablets & eReaders Logo
E
Elena romano Posted on Aug 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IPad not open CTV app - Tablets & eReaders
nexrad_chris
Level 2:
Scholar:
New Friend:
  • Expert 177 Answers
  • Posted on May 11, 2022
nexrad_chris
Expert
Level 2:
Scholar:
New Friend:
Answers
177
Questions
0
Helped
29535
Points
419
I would say close the app. Try to open it again. If that does not work then restart the ipad. If that does not work then uninstall and reinstall the program. If that does not work then contact the app's support and see what can be done.
How to open CTV app on my iPad
  1. From the home screen on your iOS/Android device, select the App Store/Google Play icon.
  2. Select Search and type in "CTV GO".
  3. Select the CTV GO application.
  4. Follow the on-screen instructions to download the application.
I have a iPad Pro and my screen has changed from a full screen to one that us 1/2 full what is my problem
How to Turn Off Split Screen on iPad Split View is enabled by default on the iPad. To utilize the feature, you can drag an app from your dock to the right or left edge of your screen to open the app on a portion of the screen. If you have multiple apps open and want to close one without turning off the Split Screen or Multitasking functions in settings, you can return to a full-screen view of a single app by dragging the edge of the app you want to remove to the edge of the screen.
If, however, by "getting rid of split screen on iPad" you mean turning the feature off completely, that's something you can do in Settings. To turn off split screen on the iPad:
  • Open the Settings app on your iPad.
  • Tap General.
  • Select Multitasking & Dock.
  • Toggle off Allow Multiple Apps.
How to Get Rid of Split Screen in Safari on iPad Using split screen in Safari on iPad was a new multitasking feature for iOS 10 that continues in iOS 12. This allows you to open two separate Safari web pages simultaneously on your iPad. To start, open Safari on the iPad. You can then open a second Safari tab in split screen in one of four ways:
  • Tap and hold a link; select Open in Split View.
  • Tap Command+N on an external hardware keyboard to invoke Split View.
  • Drag a tab from its space to either the left or right side of the screen to open it in split screen.
  • Tap and hold the icon that opens your tabs view in Safari. It looks like two overlapping squares. When you tap and hold, options will pop-up. Select Open Split View.
But what if you want to get rid of split screen in Safari? What if you're done using the two tabs-how do you turn split screen on the iPad off? To close split screen in Safari on your iPad, you can do one of the following things:
  • Drag the tab(s) from one of the screens to the other. Once the last tab has been dragged to the opposite side, Safari will return to full screen, which will turn off split screen.
  • Or, you can tap and hold the tabs icon, which looks like two overlapping squares. Then select Merge All Tabs. This will merge all your Safari tabs back into a single window, which gets rid of split screen.
Facebook does not allow my newsfeeds to come in on ipad you see blurry in back ground and cant open my messages on facebook
  1. First of all, you must have messenger app to open your messages
  2. try closing the app, restarting your ipad & re-open the FB app again.
  3. Uninstall app & install a clean version again
  4. if above didn't work; you can use safari to open your FB account as if you are opening it from a desktop/laptop
I have been using the app magic puzzles for a while. it now doesn't open. I have rebooted the ipad and updated the ipad and still doesn't open. what can I do?
First, quit all running Apps by double clicking the home button. Then swipe each one upward to remove from memory.
You have a 16gb iPad which I would not own because it is very limited with its memory. Minimum for App users should be 32 or 64gb.
Once all Apps are out of memory then hold top on off button in for about 10-15 Seconds until iPad shows Apple logo. It's Restarting.
Try your App again.....
If this fails to fix the problem then dump the App and Re download from the App Store. You own it so it won't cost anything if your using the same Apple Username & ID.
Just hold down on the App until it wiggles then click the x in the corner of the icon.
Go to App Store & find App and re download.
Hopefully this should fix the problem.
On a 16gb iPad it would be wise to not allow to many Apps to stay in Memory. Just double click the home button once in a while to clean up
Good Luck
2answers
How do I add my iPad to my Kindle account?
How to Install the Kindle App for iPad/iPhone The Kindle app can be used on any iPad, iPhone, or iPod touch with iOS 3.2 or greater installed. Installing the Kindle App Visit the App Store and download the Kindle app to start reading from your iPad, iPhone, or iPod touch. To install the Kindle app: 1. Tap the App Store icon on the home screen of your iPad, iPhone or iPod touch. You can also get the app through the iTunes Store. 2. Search for "Kindle" or find it in the alphabetical list of apps. 3. Follow the on-screen installation instructions. When installation is complete, tap the Kindle icon on your device to open the reading app. Registering the Kindle App To register your Kindle app, use your existing Amazon account e-mail address and password. If you live outside the United States and use the Kindle application, please see the Using the Kindle App if You Live Outside the United States Help page. Logging into your Amazon.com account through the Kindle app registers your device to your Amazon.com account. Once you sign in during registration, you won't need to do it again -- just open the app to access your Kindle Library. To register: 1. Tap the Kindle icon on your iPad, iPhone or iPod touch to open the reading app. 2. Enter your Amazon.com account e-mail address and password. 3. Tap the "Register" button. You can also tap the Settings icon (the cog) on the Kindle Home screen to view or change your account registration. Signing Out and Deregistering If you sign out of the Kindle app, your reading app is deregistered from your Amazon.com account. When you deregister, you can't download content to the Kindle app or send purchases to the app unless you register again. To deregister using the Kindle app: 1. Tap the Kindle icon on your iPad, iPhone or iPod touch. 2. Tap the Settings icon in the lower right-hand corner of the screen. 3. Tap "Update" under the Registration field and then tap the Deregister button. To deregister online: 1. Visit Manage Your Kindle on Amazon.com. 2. Open the Manage Your Devices section and locate your registered Kindle app. 3. Click the "Deregister" link. http://www.amazon.com/gp/help/customer/display.html/ref=hp_ipst_inst?nodeId=200438220&# installing
2answers
How to close down apps on an ipad
Double-click the Home button and you will see small windows of all the Apps that are currently open. Swipe upwards on one of these windows and it should close. You can continue this process on any other Apps that you wish to close.
Zynga poker iPad app doesn't open
Double tap the home button on your iPad and try closing the app from the row of apps that will appear at the bottom of the screen. Just press and hold the icon until the red x appears, then you will be able to close the app. Once you have closed it, try restarting the app.
If this does not solve the issue, then I would recommend removing the app from your iPad completely and reinstalling the Zynga Poker App.
2answers
How do I print out of ipad 2
If you have a Mac you can do it this way
Make sure you have the Pages app installed on your iPad.
Connect the iPad to your computer using the appropriate USB cable.
Open iTunes, then locate your iPad in the source list and select the Apps tab. Scroll down to access the File Sharing Pane.
The File Sharing Pane is a centralized location where you can manage the transfer of documents to and from your iPad. To print, transfer the desired document from the iPad to the Mac's hard drive. Then simply open and print using a device connected to that Mac or a device on the Mac's network.
Alternatively, e-mail yourself any documents you want to print, then open them on a Mac with printer access and print from there.
Printing using apps
Shop around. Each printing app works a little differently. When PCMag.com originally reported on iPad printing apps in April 2010, it found few that worked particularly well -- and several that didn't work at all. No doubt this trend has continued as developers continue to bring out new apps.
PrintCentral is an app that can be used with iPad, iPhone and iTouch. Its developers tout it as a one-stop-shop for mobile printing needs. MacWorld has awarded it 4 out of 5 mice and EuroSmartz.com has named it its iPad App of the Week. It can print directly to most wireless printers.
Whether you opt for PrintCentral or another printing app, make sure to review any instructions carefully to get the best performance.
3answers
Why wont safari let open office download?
You have to download an app for documents like Open Office to download and open on your iPad. Safari won't let you download certain files from the internet. Apps like Downloads HD are one of those apps that lets you download almost anything from your iPad and open it from within the app or from another app that can open that file you downloaded.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
