Question about Westinghouse Televison & Video
My tv is NOT A WESTNGHOUSE MY DAMN REMOTE IS THE TV IS A MAGNAVOX I ALREADY HAVE IT PROGRAMMED TO THE WESTINGHOUSE REMOTE I NEED HELP GETTING THE EMATIC DIGITAL CONVERTER BOX PROGRAMMED TO IT AS WELL
6ya staff
SOURCE:
Anonymous
  • 71 Answers
SOURCE: Magnavox model 25TSC6 0101 able to get cable tv?
you should be able to connect the cable directly to the tv, do autoprogram from the setup/channel search menu.
Posted on Jun 14, 2008
Anonymous
  • 814 Answers
SOURCE: converter box code for my rca universal remote
On the web page link below you will find the RCA Customer Support website page with all the service information for your model RCA 3 device universal remote control model number RCR311S. On this page is a pdf copy of the owners manual. You will need a pdf reader and writer to read the owners manual and a writer to make a copy for your own use.The information you are looking for is on pages 4-12 in the owners manual. I hope this information solves your problem of finding a copy of the remote control owners manual. Thank you for using FixYa and have a nice day! /RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&http://www.rcaaccessories.com/rcaaccessoriesACTION_CATEGORY_IDSTR_CATEGORY_UNIVERSAL_REMOTES&ACTION_PRODUCT_ID=RCR311S
Posted on Jun 21, 2009
John Morganti
  • 864 Answers
SOURCE: Can't receive pic and sound with converter box.
Connect the RF output of the Magnavox to the VHF/UHF (ANT) input at the back of the TV. Select channel 3 or 4 on the TV. An alternate is to connect the component output (red-white-yellow) to the Audio/Video In jacks at the front of the TV (the red or the white would be left unconnected) and use the TV/Video button on the remote to select that input.
Posted on Jul 08, 2009
John Hall
  • 1218 Answers
SOURCE: Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
Posted on Dec 28, 2009
Anonymous
SOURCE: hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
Posted on Dec 29, 2009
Have a Philips/Magnavox remote that's already programed to the television, how do I hook my Philips remote to magnavox converter box and know codes/instructions to turn box on
If your Philips/Magnavox remote is pre-programmed, try pressing a device button other than TV and see what happens. If your remote is universal, you can use code search to find something that will work.
Jul 15, 2016 | Philips Televison & Video
I have a 47" Westinghouse
Is your HDMI cable connected? Also, you should make sure that your "input" that will show on your tv when you press that button on your tv remote, shows HDMI Line1 or Line 2 (try both lines if you are not sure which line your tv is set up for.)
I needed my Sony TV code when I first set up my set, I got it from a tech from my cable AT&T uverse provider. Westinghouse may be able to give you that code as well.
Jun 09, 2011 | Westinghouse Televison & Video
I have a Philips CL043 universal remote. I can't find th tv code for a Westinghouse lcd tv.. can you help?
You can find codes for the remote here: http://www.urc.philips.com/ . Then look up the CL043 and click on the remote code finder. This is also called the SRU3004WM by Philips.
A Westinghouse TV should responds to one of the following codes: 0915, 0013, 1216, 0300 if the TV was released 6 months before the remote was programmed or earlier. (Whte Westinghouse codes are different.)
If those codes do not work, there is a manual code search option. With the TV on, press and hold Setup on the remote until the red indicator stays lit. Then press and release quickly the TV button on the remote (the LED will blink once). Then press the Channel Up button until the TV responds (up to 300 times). If you overshoot, press Channel Down to go back to the previous code. Press and release the Mute button to set the code. Check if the remote performs all the needed functions. If it doesn't, repeat the above steps to find another code.
I hope this helps.
(if the remote is older than the TV, you may need a newer universal remote.)
Jan 08, 2011 | Philips 5-Device Universal Learning Remote...
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
Code to program a Magnavox television.
the easy solution is to buy a new universal remote cost about 8 to 10 dollars but if you dont want to spend money just point the remote you have to the tv. and start clicking
till the tv. is off thas the solution
Aug 15, 2009 | Westinghouse SK-32H240S Television
I have a rca remote (rcu404) my tv is a magnavox. I can not find my book so I need help finding the correct code to program the remote to the tv. Thanks I do not have the code book for my remote control....
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
Jan 14, 2009 | RCA RCU404 Remote Control
Remote code
Hi beutyful24_7,
There are two codes for your remote that work with White Westinghouse TV models: 311 and 611.
For your reference, here is a web address that includes all the codes for your remote, along with programming instructions:
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | Philips Magnavox Learning Universal Remote
Remote Control Programming
Ihave magnovac tv. and found the old remote control. but I do not have the code. Please help
May 25, 2008 | Philips Magnavox Learning Universal Remote
Get Direct TV Remote to TOTALLY work with Magnavox TV
My TV remote has a slide-switch at the side to switch between the TV, DVD or VCR. I don't know if yours has one, if so, switch it to TV. It also has a button to switch between Analogue, Digital and External, so make sure if you have a button like this that it's switched to the right input.
Jan 28, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Televison & Video Logo
18 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
