If error persists reset the thermometer by removing the batteries and putting them back in. If error still persists contact your Welch Allyn representative. To change default temperature scale: With the device off, press and hold the button for about 5 seconds. Release the button when desired scale is shown.
SOURCE: Can't get the battery cover
I just figured it out.
Holding the device so that the ear piece part is pointing towards you, locate a little raised arrow on the top of the device, just below the battery cover.
The arrow points to a little hole, which you need to push something sharp like a pen point into. This should release the cover, which you can now slide off.
Mine did not release so easily, so I also used a flathead screwdriver (a pretty small one, only about a 1/3 inch wide) to drive in between the body and the battery cover, twisting it off as I pushed a pen into the little hole.
Should work fine. Now you just need to get those weird lithium batteries it uses!
Good luck.
SOURCE: have a braun thermoscan and want to change it from...
From the manual of the thermometer:
This thermometer is shipped with the Fahrenheit temperature scale activated. If you wish to switch to Celsius (°C), proceed as follows:
• Turn on the thermometer. (If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
• By pressing the activation button again, the Celsius scale is activated, «°C» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
If this isn't the right manual, go to: http://braun.kaz.com/kaz/service and select your country from there.
SOURCE: how to change batteries in
push down the small button directly above the battery door with a pen or something slender, while pushing the battery door downward, away from the thermometer. the 6012 model uses two CR2032 button cells.
SOURCE: I have a Braun thermoscan type 6022, but code po5
It's not po5, its pos... you're not positioning it properly in the ear canal.
SOURCE: Can you change the temp
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
