SOURCE: Need t replace belt on Maytag Ensignia MDE4658AYW dryer
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
SOURCE: user manual for Maytag DE313 Series 107
(Click below for user manual)
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=RF262LXSB0&siteCd=WHRCOM
The age of your dryer I'm not sure, The elements for your dryer can be found below, go to my web-page and enter the model DE313 into search feature and you will get pictures of the parts. The element part# is Y313538 (click link below)
http://servicepartstec.blogspot.com/
If you need help, just let me know,Thanks,Sea Breeze
SOURCE: Belt Replacement
Try Googling " user manual for Maytag Ensignia MDE4658AYW ". You may have to go to the Maytag web site and ask for manual. Sometimes I've had to ask for repair manual instead of user manual. Good luck.
SOURCE: Maytag Gas Dryer
there could be a few things going on here,,,
first the simplest, make sure your exhaust for the dryer is clear and you can feel a good amount of airflow.....
second,, try to peek inside the dryer, often does best frombehind,,, make sure during start up you can see your ignitor glowing ,,, if it does listen for a decernable click,,, tha would be the gas valve,,,
no glow....no go
no clunk..coils junk
SOURCE: Hello, I bought a used
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
