Minecraft pe,new xbox live acoaunt i created just awhile ago
Unable to login. If you're logging into the Minecraft game client and you receive the error "Login failed. Invalid username or password.", this means that you're using incorrect login information. ... If you receive a technical error message when you try to log in to the launcher, please visit our technical help resources.
SOURCE: xbox live subscription code
you should be able to either call xbox or email them the problem and they will be able to help you, you just bought the 3 month subscription I believe and if it isn't working, then it is there problem, that you need them to fix, maybe give you a different code
SOURCE: I can't connect to xbox live 'cause of an udate loop.
You could maybe chalk it up to bad connection or maybe the box is banned. You could try downloading the update from Microsoft's website and update that way.
Here's the link
http://www.xbox.com/en-US/support/systemuse/xbox360/console/systemupdates.htm
Hope this helps
SOURCE: battlefield bad company 2 cant create EA account?
Guys - here's the deal. doesn't matter what your parental settings are. If you used your birthday day when creating your xbox live gamer profile, which can't be changed even by microsoft xbox live support, and your under 18, then your out of luck. Call xbox live supports 800 number and explain the problem. you will eventually talk to a supervisor and they will offer a 6 month free subscription to xbox live which you use to create a new profile (with an adults date of birth). You can use your old profile for other game until it runs out, then let it expire.
SOURCE: I have a child account for my xbox live account
You will need to upgrade your child account to an adult account to be able to use Netflix. Unfortunately this is not possible until the child reaches the legal age of 18 (US).
Once a child account is created it is managed from the date of birth indicated when applying for the account.
Netflix can't be bypassed to work on an Xbox 360 on a child account.
The only solution to view Netflix on the Xbox 360 is to have an adult account created and access via that account.
Recommend that you just stream using your computer. Plenty of options out there to get your PC hooked up to your TV if you need to view in a larger scale.
Testimonial: "Thanks for the clarification!"
This problem might be due to slow internet connection.
Perform the following steps:
- Restart router
- Update the browser
- Disable Antivirus and firewall
- Update the drivers that control your PC
If problem still occurs then visit following website - as it has some relevant helpful material related to Minecraft. http://www.MinecraftBadVideoCardDrivers.com
